  • Replies 49
Posted Images
i rekon really loud cars.. deter women.. they'll probz just look at u and say "what a looser" ;)
Like the driving add when that guy does stupid thing son the road and everyone does the little pinky haha.
Twin 3" from Turbos FTW :(
depends if its NA or forced induction...
If you think your rb25de with a 4 1/2 cannon cuts sik with more power... Then tempe has your next set of wheels.
NA Needs to flow but not as much as a forced ind. motor.
2.5" - 3" max for NA.
As VashR31 said... with NA you *can* have too big an exhaust. 2.25 - 2.5" is the largest you want to go... after that you start to loose power down low. I had a 3" JASMA turbo exhaust on my NA 33 when I got it... put a 2.5" custom setup on it and it's got a noticeable torque increase down low in the rev range.
For a turbo however, the backpressure is generated by the turbo itself... after that you want as much flow as possible. On a turbo you could run 6" all the way from the turbo, straight out and it would go beautifully... and be freaking loud! In reality though, anything larger than 3.5" is just for show... sure it won't do any harm to performance but it'll drone like buggery and be way too loud... not to mention defectable ;)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
