Yup, well finally, here is my little R34 SKYLINE, Manual GT-T Sedan.. Pearl White and it is simply a pleasure to drive, since July I've done close to 15,000km in it and I'm still not bored.
Considering I used to drive an N/A auto VL Berlina, this is an entire world away from that... These pics are after I gave my car its first cut-back polish and wax.. Again, a big thats to Paul, Alistair and all of Autoworx who at the time help me with the car, big thanks to you guys.. I'm really a happy chappy!
Edited by Marco-R34GTT
https://www.sau.com.au/forums/topic/200799-finally-my-r34-gt-t-taxi/
Just a question dudes and dudettes...
Does anyone think that my wheels/rims don't fill the guards enough??
A few of my mates have said this and I kinda see their point.. Are they right? or am I delusional??
Bigger rims? Get some aftermarket springs/shocks for a lower ride height??
I can report this though, I don't know if many Skyline drivers take their rides on gravel roads, I have to as I live in the country, but I can tell you all.. The Skyline is equally at home on gravel as it is on bitumen, many of the locals that drive typically 'country' cars, such as commodores, falcons, magnas, statesmans, avalons, aurions and the likes.. None of them, and I will say, NONE of them handle, road hold and are as stable as the Skyline... Really me and my old man couldn't believe it, but it is true, and I have no idea how they (Nissan) managed it, but this thing is just simply awesome on gravel..
thats a hell clean 34 mate, good work on gettin it hehe, as 4 the wheels they do sit in a bit, wat u can do is either get a new set with lower offset, or just whack sum bolt on spacers 4 those rims, if u want 2 lower it id recommend gettin sum coilovers.
Oh, I thought it was an N/A GT-4...
Yeah, that is one thing that really suprised me too, going from a VL though, what do you expect... The VL used to handle like a shopping trolley on cocaine...
  • 3 months later...
hey mate.
what size rims are u running.
like size and offset.
i have a r34 4Door also. except mine is a GTS model.
i have just put on some axis Hiro 19x9.5 +25 all round on mine. And i must say they certainly fill the gaurds ha ha
a big car needs big tough jap looking rims.
hey mate.
Any pics mate? U would have had to roll ur guards??
yer at the moment is running stock height so there mega clearance.
But i will get my guards rolled and pumped so that i can lower it heaps.
the wheels sit outside my guard alittle bit. but once i pump out the guards and lower it the wheels will also camber in abit which will help out a bit.
The wheels look phat as tho.
here is a pic with my car riding at full height. Needs about -5inch suspension. :thumbsup:
  • 3 weeks later...
Hey mate, nice car, ive got a 34 4-door as well. Ive got the R34 GTR rims on mine with lowered springs, fill out the guards pretty nice. Cant go wrong with a decent set of 18s. If i was you id get some work XT7s for it in bronze. Very nice car though mate, nice and clean, good to see more of these puppies getting around. Here's a pic of mine:
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
