Hey all,
So I've only had my GTR for a couple of months, and now that I've stopped babying it and started driving it "properly", I've started to notice something weird..
When I make a right hand turn (with a bit of pace), the red (!) light on the dash comes on - i.e the handbrake light, but I assume in this case the car is trying to tell me something different. And sometimes it stays on for a little while after the turn.
Has anyone come across this before? Does it sound like a damaged engine mount causing the engine to rock too much or something? Or maybe a HICAS fault?
FWIW it's a 1994 R32 GTR with a bunch of mild mods (exhaust/intake/highflowed turbos/apexi FC/boost) and Buddy Club coilovers.
low brake fluid mate. check the master cylinder for level (and your pads are probably pretty low too, or you might have a minor leak at the master cylinder). Brake fluid shouldnt go anywhere so if you top it up and the light comes back later get the master checked out properly.
    • yeah, there's a country that recently started importing Skylines, I blame them.
