EDIT: Look at post on page 2 for results.
My cars giving me grief again and i dont know what the hell it is. Quick rundown
r33, stock turbo at 0.9bar, walbro fuel pump, jj cooler, pod with box, fpr, turbotech bleed valve, hks FCD, kakimoto 3 or 3.5" full exhaust with unkown cat
dynoed at 204rwkw last time. 13.5 qtr
drove to QLD and on my drive there i felt the car lose all its balls. looked at boost gauge and it would drop from 0.9 to 0.6bar at redline so i though it was the apexi pod i put back on
i done the intake pipe mod to re-enforce it and changed back to other pod, also cleaned afm and aac valve. no change
changed BOV from atmo to stockie, no change
sparkies are 20k.s old, platinums at 1mm gap which i havent checked yet
now without going and spending cash on dyno runs etc which i may well have to do i want to know what the likely hood of a blocked cat is and if this is causing the power loss??
it does not feel like it is misfiring and i have rechecked all IC piping clamps and they seem secure. Also changed a couple vacuum hoses here and there
oil pressure it a tad higher than usual (prob not related) but maybe coz i slightly overfilled. It slightly sits above the first line on the gauge on idle and just over 3/4 on full load
i rekon no way its the cat and ill just waste my time pulling the exhaust off (scared of undoing those rusted nuts lol)
any input??
Edited by tek_01
Does it also make boost slowly ??
If so then I would definitely check your cat. I mucked around for ages trying to find why my car struggled to make boost. The cat had collapsed and was causing a large amount of back presure.
Tim.
so it looks like it could be the cat
it is laggy i guess but it has always been like that, under 3.5k it is useless even tho it is standard turbo
in case it is the cat, what is recommended? i hear metal cat is the go but lately a lot of people have had theirs fail
Im having a similar problem. More lag from low rpm and not as sharp when i press the throttle. Around town sounds like i'm driving an NA :P
I'm guessing its either wastegate actuator stuffing around OR this thread made me think it could be exhaust blockage. It's rusted out after the cat so i might pull it off and see what happens.
yeh just make sure u secure the rest of the exhaust if u leave it on lol. dont know how it will drive with no exhaust tho??? ive had holes in my old car and it wouldnt bloody move
turbos are some temperamental!!!!!
if the cat has shit itself the sensor should tell you it has. i'd be checking the plugs before you dish out money, and/or changing them to 0.8 gap rather than 1.0mm.
can you hear any sort of high pitched hissing noise under boost? have you checked all your piping?
Edited by dmr
to be honest i wouldnt know how to identify pinging. would prob have to get a pro to look at/listen to it
no hissing to speak of apart from the vacuum sounding air filter lol
why should i re-gap if it is not missing???
i would be able to feel if it is missing wouldnt it?
I have a similar problem but I know for a fact it's not the cat.
I can set 0.9 bar and it will hold that for a short while and will then drop off to about 0.6 bar like you, strangely I also made 204rwkw's. Also my turbo is very responsive and will raise boost very fast, untill higher RPM.
I have checked the usual things like rubber intake pipe sucking in, wastegate pre-load (which I increased with no better sucess) now I am thinking maybe it is a restrictive exhaust. I have a 3inch stainless dump/front, 4 inch stainless catback though it has two mufflers and even with 204rwkw's the car is very quiet..... I was thinking of just dropping the exhaust at the cat for one run to see if the boost holds.
I have also been told that maybe the stock Turbo is just running out of flow, maybe but hardly anyone else has that prob.
Edited by FighterJoe
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
