EDIT: Look at post on page 2 for results.
My cars giving me grief again and i dont know what the hell it is. Quick rundown
r33, stock turbo at 0.9bar, walbro fuel pump, jj cooler, pod with box, fpr, turbotech bleed valve, hks FCD, kakimoto 3 or 3.5" full exhaust with unkown cat
dynoed at 204rwkw last time. 13.5 qtr
drove to QLD and on my drive there i felt the car lose all its balls. looked at boost gauge and it would drop from 0.9 to 0.6bar at redline so i though it was the apexi pod i put back on
i done the intake pipe mod to re-enforce it and changed back to other pod, also cleaned afm and aac valve. no change
changed BOV from atmo to stockie, no change
sparkies are 20k.s old, platinums at 1mm gap which i havent checked yet
now without going and spending cash on dyno runs etc which i may well have to do i want to know what the likely hood of a blocked cat is and if this is causing the power loss??
it does not feel like it is misfiring and i have rechecked all IC piping clamps and they seem secure. Also changed a couple vacuum hoses here and there
oil pressure it a tad higher than usual (prob not related) but maybe coz i slightly overfilled. It slightly sits above the first line on the gauge on idle and just over 3/4 on full load
i rekon no way its the cat and ill just waste my time pulling the exhaust off (scared of undoing those rusted nuts lol)
any input??
Edited by tek_01
Does it also make boost slowly ??
If so then I would definitely check your cat. I mucked around for ages trying to find why my car struggled to make boost. The cat had collapsed and was causing a large amount of back presure.
Tim.
so it looks like it could be the cat
it is laggy i guess but it has always been like that, under 3.5k it is useless even tho it is standard turbo
in case it is the cat, what is recommended? i hear metal cat is the go but lately a lot of people have had theirs fail
Im having a similar problem. More lag from low rpm and not as sharp when i press the throttle. Around town sounds like i'm driving an NA :P
I'm guessing its either wastegate actuator stuffing around OR this thread made me think it could be exhaust blockage. It's rusted out after the cat so i might pull it off and see what happens.
yeh just make sure u secure the rest of the exhaust if u leave it on lol. dont know how it will drive with no exhaust tho??? ive had holes in my old car and it wouldnt bloody move
turbos are some temperamental!!!!!
if the cat has shit itself the sensor should tell you it has. i'd be checking the plugs before you dish out money, and/or changing them to 0.8 gap rather than 1.0mm.
can you hear any sort of high pitched hissing noise under boost? have you checked all your piping?
Edited by dmr
to be honest i wouldnt know how to identify pinging. would prob have to get a pro to look at/listen to it
no hissing to speak of apart from the vacuum sounding air filter lol
why should i re-gap if it is not missing???
i would be able to feel if it is missing wouldnt it?
I have a similar problem but I know for a fact it's not the cat.
I can set 0.9 bar and it will hold that for a short while and will then drop off to about 0.6 bar like you, strangely I also made 204rwkw's. Also my turbo is very responsive and will raise boost very fast, untill higher RPM.
I have checked the usual things like rubber intake pipe sucking in, wastegate pre-load (which I increased with no better sucess) now I am thinking maybe it is a restrictive exhaust. I have a 3inch stainless dump/front, 4 inch stainless catback though it has two mufflers and even with 204rwkw's the car is very quiet..... I was thinking of just dropping the exhaust at the cat for one run to see if the boost holds.
I have also been told that maybe the stock Turbo is just running out of flow, maybe but hardly anyone else has that prob.
Edited by FighterJoe
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
