Hey guys, well I have just got back from Top Secret and they are keeping their R35 project pretty hidden away and appear to be working furiously to get it to where they want it ready for Tokyo Autosalon in a few days time.
The only visible changes at this stage are some mild exterior touches, the usual Top Secret sticker collection and their trademark Rays GT-C's wheels with gold centres.
The photo isn't the best, its been very overcast today, and the workshop is closed off.
https://www.sau.com.au/forums/topic/200832-top-secrets-r35-gtr/
  • Replies 101
I feel sorry for the STI and EVOs, no one's even giving them a glance.
That's what Mitsubishi and Subaru get for releasing new vehicles within the same year as Nissan releases its GT-R. They should have either released them at the beginning of the year, or some time next year. :thumbsup:
Its like movies that had the same release date as the Star Wars: The Phantom Menace or Transformers. They weren't going to get a look-in on that weekend, no matter how good they might be in isolation.
The only companies that would have a hope of competing with the GT-R for attention would be if Honda released an all-new NSX. Even the Lexus LF-A, with its apparent GT-R beating Nurburgring time and F1-inspired V10 engine, doesn't have the history to match the hype surrounding the GT-R.
And the fronts look like they need less offset. There's not enough dish.
Part of the charm of the older GT-Rs is being able to run low offsets and get mad dish / concavity to make the car like super wide.
Agreed
isn't that an S2000 in the poster above it?
I don't know for sure, but if you look close enough at the poster, it shares the same style C pillar with the R35 GTR.
I can't make out whether it has the trade mark stove plates though.
Anyone else notice the GTR poster in the background (above GTR) with different body kit? Maybe a hint of what is to come?
Its the Topsecret V12 Supra
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
