  • Replies 69
I don't get it.... Almost anyone that's been to Spats raves about it. I've been there twice with the mrs and friends and both times the smell in that place was absolutely disgusting (if you can imagine strong parmesan cheese mixed with vomit).... I won't go back there!
parmesan cheese smells like vomit already, how can u distinguish between the two? heh
if you're after a nice brekky for two, najjars cafe on oconnell st makes one of the best english breakfasts u can imagine and its a nice lil' cafe, not too busy
-D
thank you sir!
She is vegetarian, i'm sure they are ok for that? most places are now.
if shes a full on vegetarian then i would highly recommend this place
http://www.zenhouse.com.au/
Just off rundle st. Been there a few times with a mate who's vegetarian and they have very decent food, meals under $20. The atmosphere is very relaxing and the place is fairly cosy and inviting.
Good for a first date, perhaps a bit on the quiet side tho, better have some ideas for conversations. :bunny:
I took my girlfriend out to this place last night: http://www.scampis.com.au/
Food was good, we had the executive platter for two(a whole lobster with loads of other stuff) - bit too much cheese on the lobster I reckon but apart from that the meal was nice. Only problem I had was the attitude of one of the waiter - ordered drinks entree the usual, she goes off do whatever while we decide on the main, she comes back and we ordered executive platter for two and then she goes off saying we dont need the entree the main is pretty huge etc etc in a real poor attitude tone/offensive body language(the way she was standing) - for a fancy place by the beach and a customer spending big dollars buying their best meal I would expect better - made the experience there a bit average, I sure wont be going back.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
