ok, my extractors are getting fitted tomorrow, they are cutting off the original final 2 into 1 cone that has a 2inch diameter and replacing it with a 2 1/2 inch one to suite the rest of my system. Ill let u all know how it goes.
Guest R33Glenn
Hey pipols, i got my extractors fitted last Friday, and i can only describe them as excellent, definetly more tork in the low to mid rev range, and it 'seems' to go harder in the higher end of the rev range as well, they allso enlarged the final few inches of the extractors to 2.5 inches.
Guest R33Glenn
cool greg, my exhaust is a little louder at idle, and a bit more throatier on acceleration, but i only have the standard exhaust with standard cat, with a lukey sports muffler, it seems that my standard exhaust is 214 inch in diamater, is that the standard factory size? im planning oh a high flow cat, and a 212 inch system soon, or maybe even a 3 inch, but dont know if the noise will be to much if i went the 3.
dont go 3 inch u will lose performance most likely cos lack of back pressure! keep it at 2 1/4 - 2 1/2 ", wat kind of lukey muffler is it ? get a hi flo cat as well, catalytic converters are so bad, mine is flanged and wen i take it off and put the pipe there it makes a huge difference.
there are other ways round buying a high flow cat, they are very restrictive and pratically useless after 60000k's neways. Apparently i read somewhere that a well tuned rb engine will still pass an emissions test without one? dont know how true that is.
my car came with a HKS 2 1/2 inch Super Drager exhaust, the extractors are "Coby" brand, ordered from www.partsco.com in New Zealand i think. I modified the final 2 into 1 section of the extractors to be 2 1/2 inch diameter to match my exhaust system.
    • Was not scared.....  😬😬😬 20250222_153105.mp4   Now what.......?
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
