Well, after a couple of months of sweating the ID inspection, I got the 34 with NSW plates through Sturt Police today.
I thought that it would be referred to Regency for further inspection but it didn't happen. One of the boxes on the inspection sheet asks if further inspection is necessary but he ticked the 'NO' box......whew. :thumbsup:
Obviously coilovers, lowered slightly, airpods, wheelspacers, Kakimoto Dual N1 exhaust & BBS wheels with 265 rubber are all OK as long as they're within spec and all mounted well.
Now I can finally bolt on all the stuff that I've been acumulating for a few months.
good to hear :thumbsup:
Thanks Cara
hey congrats man!
post up some pics with the new goodies??
Thanks, I'll try.........but its things like bigger garrett turbos, cams, power fc, hks elec boost controller, injectors, fuel pump rail & reg, bigger tube & fin fmic, different air pods, improve existing exhaust with split dump pipes etc, better clutch and a few other hidden things.
Most of that stuff you don't realy see unfortuantely.
what garret turbos u thinking?
Wanted to stay low mount so I've already bought a pair of GT2860R 707160 -5.
No point in going top mounts or big single unless it sees the track or drag strip more than the street.
Not wasting any time are you? 350-400rwkW here we come.
*cough* and some 32s * cough*
*cough* and some stageas *cough*...lol ;)
Seriously though, the 2860rs -5 are basically the same size as the standard turbos from the research ive done recently, just with steel wheels.
Ive just fitted the 2860rs-7 to my 260rs, which in my case was the biggest i could go and keep them low mount cos theres not alot of room under there! The next up from there is either a -9 or -10 which the exhaust housings were too large to be mounted, but also they dont come on boost til very late either so it doesnt make it very streetable as a daily.
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :(
*cough* and some stageas *cough*...lol >_<
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :P
i think you got the sizes mixed up
2860-5 (2530's) isnt same size as the standard turbos, and -5 is bigger than -7
Had me worried there for a minute :) . Just did some research and found the standard turbos have a .53 housing (actually stamped on the turbos) where the -5 has a .60 & .64 respectively. The -10 has a .64 with an optional .86 housing (too laggy for street and too narrow power band).
Also found out something interesting.....all new GT28 housings out of Garrett now are stamped 2560R but specs are still the same as 2860R....this straight from their website:
For those familiar with our product range, this means that the unit formerly known as "the GT28R" (part number 466541-1) is now in the GT25R family. More specifically, it is now a GT2560R model.
Wow, I can't believe it got through with wheel spacers - it really was your lucky day.
Sounds like your plans are for a nice tough real streetable GTR.
Surprised me thats for sure......probably because the wheels are just inside the guards that he didn't look or care about it.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
