R34 GT-R (http://www.performancecars.orcon.net.nz/ca...an/godzilla.htm)
Length: 4600mm
Width: 1785mm
Height: 1360mm
Wheelbase: N/A
Kerb Weight: 1,540 kg
R35 GT-R (http://en.wikipedia.org/wiki/Nissan_GT-R)
Wheelbase2780 mm (109.4 in)
Length4655 mm (183.3 in)
Width1895 mm (74.6 in)
Height1370 mm (53.9 in)
Curb weight1740 kg (3836 lb)
As you can see from the dimensions (i hope these are accurate) there isn't a huge difference. The only large difference is width (which is most noticable to my eye) which is 10.1cm wider on the R35.
I'd say the sculpting of the body on the R35, being more shapely and voluptuous, gives it more visual mass than the hard-lined R34, which looks more like a dart. If the 34 nose was wider you'd find it hard to say there was a massive size difference.
Proves how body design can convince you of a certain 'sleekness' or 'toughness' depending on how low and broad a car is, or tall and slim.
Edited by R338OY
