Hey everyone,
My 32 GTR has a problem, it has all your basic mods, n1 turbos etc etc.
Today it started doing a few funny things. When I a accelerate, the car might hit say, 2500-3000 rpm then start stuttering/hesitating,
i'll put it in 2nd, and it might hit around 4000rpm and just cut out, as in stop accelerating all of a sudden. If I play around with the gears,
the car will get moving again.
And sometimes, it runs real good, in 1st/2nd, but 30 secs later it will have the hesitating problem, the car gets stuck at a certain RPM and refuses to budge,
unless I shift up or down. And it even almost stalled once, revs dropped to 0, i tapped the accelerator right before it would have stalled. It is strange that i cuts out completely,
usually, if a car pings, you keep accelerating, it will hesitate, but get through the rev range. Whereas in this case, it does not.
Going to the mechanic tomorrow, but has anyone had this problem before, in case it is something simple I can fix.
Thanks.
Edited by IOWNU
https://www.sau.com.au/forums/topic/200879-r32-gtr-running-poorlyhelp/
umm sounds very similar to my issue and i have followed the tut on cleaning the afm and checking the solder.. still happening.. does anyone know voltage the afms should be seeing normally
Just change the AFM, no point stuffing around with a stuffed AFM.
I had to change 1 and now its running fine.
Thanks for the help guys.
the power supply to the ignitor and the earth wire at the back near the ignitor...check those harnesses..had the same problem with same symptoms with my old GTR....bcos i was getting the coil cover resprayed had to move the wires and cos its older car the wires can become hard...and think thats was caused mine to cut out etc as above
hope that helps if it isnt the AFM
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
