hey everyone im currently building my engine and want to go d-jetro with the apexi but i own an rb25det and they dont make the d-jetro unit to suite. but i have heard on the grape vine that u can make a bcnr33 d-jetro computer fit the rb25det is this true any help would be gr8ly appreciated
https://www.sau.com.au/forums/topic/200896-apexi-power-fc-query/
It is possible that i know of with the standard pfc on the rb25det with no vct im sure the d-jetro pfc should work check out the thread about the power fc into the gts series if you were in melb there is a workshop that does the install
  • 2 years later...
HEY i have same question. i wanna install a D-jetro on my r33gtst@ rb25det. (740 inj, gt30, poncams, cp pistons,N1 Oil & waterpump, gtr crank, walbro FP, Z32 MAF, nismo FMIC, Mocal 20R oilcooler.....)
I wanna change the maf to map 3,5 bar.
Do i have to change some wiring? do anyone have exp. with that?
big thx
Marcus
as mafia said search for the info, it's all out there
it's not a simple sensor change, you need to get BCNR33 PFC, then change the wiring, then change the tune, then you loose VCT
it's a lot of work just to run a map sensor. whatever you can achieve with the map sensor, you can do with AFM
and a 3.5bar map sensor is only 2.5 bar boost you know that dont you?
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
