Hey peeps,
Just after peoples opinions on mobile phone kits, what your are using or seen and prefer.
I'm currently using a Nokia CK-7W and think it's great.
Cost about $115 delivered.
Has Bluetooth connectivity and you can press a button to answer, or press and hold and say the name to call (if it can recognise what you say)
I was thinking of getting another one of those for our recent new car (non Skyline...and 2nd hand)
But, I've also stumbled on the CK-15W which looks similar but has a fancy display.
The best i can find is $229 delivered for that one.
Anyone using other kits (preffereably Bluetooth) that you could suggest?
Cheers..Birnie
Wow the 616 is a pricey kit. Must do a good job though
I've bought a non-nokia kit once before and it sounded so bad, i took it back and bought another cheaper Nokia that sounded better.
What sort of feedback on the Parrots?
its a 8w car phone thats why the hefty pricetag. I get into some wierd spots and the phone needs to work.
feedback on the parrot items is almost nonexistant.
I ordered the 15W yesterday...waiting for delivery
6110's not working with the CK-7W's?
That's odd.
It's actually a pretty simple device only looking for Bluetooth devices so i can't see why it wouldn't if it has Bluetooth?
CK-7W is a great/simple/cheap unit by the way.
Have one in the Skyline now.
There is a 20W but i can't find much info on it.
Only has pics of the little swivel unit ??
Have had dramas of people's 6110 Nav's not running with a CK-7W.
Is there a Nokia CK-20W...? Apparently it is meant to work. Chris...?
dunno, never used it. 7w & 15w are my usual ones. I will say that the 616 does fight with the 6120 I have occasionally. one of them drops the BT link and I have to manually reset it. oddly enough it works fine with my old 6230.. go figure.
6230's and 6230i's are gun phones - had one for three years no need to upgrade yet.
But yes CK-7W and 6110 navs - keeps dropping out of bluetooth. CK-20W apparently works.
I got the pioneer 9850 head unit has built in bluetooth works really well, auto connects when i turn the car on, cuts the music out does all the right stuff, and i got one of those little portable speaker type ones in my ute a sudio its called works ok but u find yourself leaning towards it so the person you are talking to can hear u better, i put in on my sun visor and its a pain in the ass cause u have to charge it.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
