which oils are you guys using in your tranny and diff?
i've been searching all over SOC and SAU but i cant really find a definate answer, specially on the diff oil.
I'm looking to get some redline oil and was thinking redline lightweight shockproof for the Gearbox but i'm not sure at all what to put into the diff.
Would i be better off with heavyweight shockproof in the gearbox?
https://www.sau.com.au/forums/topic/200912-gear-and-diff-oil/
R33 gtst
really? i've seen a bunch of people recommend redline before
MoogLe,
I gave my NA 33 GTS a full service last weekend... so that included gearbox and diff. I use the Redline Lightweight Shockproof that you mentioned... it's damn expensive though... $130ish for 5L (box takes about 2.5L). My gearbox is a little worn and slightly 'notchy' sometimes, so this is a worthwhile investment (I put some in about a year ago, then blew my clutch. when they changed my clutch they drained my oil!). If your gearbox is in really good condition (i.e. smooth into and out of every gear), don't bother with the redline.
As for the gearbox, I used Penrite LimSlip 90, simply because that's what Penrite suggested for my car ;)
MoogLe,
As for the gearbox, I used Penrite LimSlip 90, simply because that's what Penrite suggested for my car >_<
you mean diff in the last part?
now i'm doubting wether i should use heavy of lightweight shockproof oil,
i've been recommended both, still lost on the diff too, doubt i'll find pennrite around here, never even heard of that brand
what car is it going in?
redline is used mainly for old noisy gearboxes.
I would try something like motul.
Read the oil thread:
http://www.skylinesaustralia.com/forums/go...0&start=780
I think your referring to Redline lightweight shockproof which is often used for older gearboxes.
Some people say its fine in newer gearboxes some people prefer MTL or similar.
I used Redline 75w90 in my mechanical GTR rear diff. Obviously if you have a viscous diff you would be using something else.
There's a guy called http://performancelub.com/ that sells redline pretty cheap.
Regards,
Gareth
Regards,
Gareth
you know,
i emailed Redline through their website to ask for their recommendation and they recommended me the exact same stuff you did
MT90 in the gearbox and 75w90 in the diff.
so i'm gonna go with their recommendation. After all, who knows their stuff better than they do?
Edited by MoogLe
Redline Shockproof is made for gearboxes that do not use synchros...skylines have synchros therefore redline is not good for skyline gearboxes..
im using motul everything..its expensive but its good..for gearbox theres motul 300 gear but i couldnt find that so im using motul gear ff competition...Got it from the local autobarhn and the guy there is a rep for motul so he was very helpful :D
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
