FS: 1997 R33 Nissan Skyline GTST M spec
Rego: 9 May 2008
Price: $17 000
Colour: White
Contact: Simon 0401 471 604
Odometer: 67 xxx km
Comment:
This is a very beautiful car, which drives very straight and is very smooth. I am the first oz owner and have owned the car since May 2007. Reason for sale is that I am now after a motorcycle. The car has KYB damper adjustable suspension with matching springs, Front and rear Cusco strut braces, 3” bullet front pipe with 1 week old kakimoto regu cat back exhaust, 17” panasport G7 rims with 4 week old Toyo proxes 4 tires, engine is running HKS s40i spark plugs, split fire coils installed at 59 xxx km, car serviced every 5000km with log and receipts, bass junky silicone turbo intake pipe, front mount intercooler, Apexi AVCR boost controller, razo turbo timer, greddy gear knob, double din cd player will not be sold with the car but another cd player and genuine Nissan din pocket with lid will be provided with the sale, Nismo 2 way lsd, K&N panel filter in original airbox with cold air induction. Car also has ABS. Car will also be sold with a HKS FCON S computer and have been quoted $900 fitted and tuned by Tom at BD4.
Inspections can be done in the Sydney area, please no tire kickers and jet pilots.
Overall the car is very clean inside and out, all panel lines and spacing line up and are equal either side. Interior is immaculate and exterior is in very good condition.
Edited by rocketeer
https://www.sau.com.au/forums/topic/200914-1997-white-r33-skyline-gtst/
  • 3 months later...
Price drop $16 000, car is still up for sale, will be sold with 12 months rego, current km is 71 000km, 70 000km service done, will swap for jzx100 or other cars of interest, prefer turbo manual. Also Blitz bov and filter have been removed and have been replaced by the standard airbox with k&N filter and runing standard bov. Jap Double din cd/md player will be sold with car. Also added Jap style kenwood 3 way speakers on rear parcel shelf.
Edited by rocketeer
  • 3 months later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
