  • Replies 245
DING DING! FIGHT!
actually I reckon the focus will go really well
dont forget dale that the focus is really designed to handle well
I am not saying the n15 isnt - just the focus is newer etc
dale you going to get some whiteline adj swaybars?
you and your logic can just stay right out of this thank you very much! :P
motokhana at Midvale - I can't do the March one as I won't be in the city. I will, however, be getting some practice in while I am away so I can chop youse like kindling at the next one
swaybars - yep, hopefully soon!
:O
*runs off crying*
Srsly, I am going to be in Donnelly River for the long weekend. Have you ever driven down there? The roads are teh sexiness. The run from Bridgetown to Donnelly river has some of the best cambered corners in WA IMO so when I get back I will be chomping at the bit for some track work.
Brad.. I'm not married yet so.. wanna hook up? :D
Sounds like Dale wants to join in aswell LOI
P.S. I could watch that midget face sliding all night!
I am SO already there dude
*snaps fingers*
Teh Pulsar Fury will pwn joo ALLL!!!!!!!11!!!!ty
*edit* note to self - STOP DOING THAT!!!! (just remembered a: its not timed
b:my missus is driving, not me) :)
Why aren't you driving? is it because when you LOSE you can blame someone else? :P
Note: I like to touch myself in public ;)
Nah, we both went down with a few of the SAUWA guys a month or so ago, but it was arse breakingly hot and the missus never ended up getting a decent drive because she felt like poo, so she sat in the shade and watched me thrash the car within an inch of its life. Ergo, this time its her turn.
Dale, So now I'm racing your Mrs and not you ? She's probably a better driver than you anyhow :(
Yeap, the Mrs was always gonna do this one because she missed out on the sheer unadulterated hoonery of the last track day.
On the upside, my trip down south has been cancelled so I will be coming to the speed dome event now, and I a bringing a whole sack of fresh chop with me :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
