  • Replies 245
well its slowly getting closer and closer :) cant wait ( even though I am not driving ! )
rear swaybars are in and god only knows wheh the right front bar and the rear subframe bushes are going to arrive! like a kid in a candy shop!
well its slowly getting closer and closer :P cant wait ( even though I am not driving ! )
So, tell me Sean, exactly how does a kid in a candy shop THAT IS ABOUT TO PWND BY TEH PULSAR FURY feel then? :)
Guys sorry i have not looked at this thread in days. Had other things going on, but now i can get back to this....
So Mitchy and Kylie have wussed out (j/k) so that leaves 4 Spots open.
Sam, yes you can enter this event if you like, however THIS IS NOT BURNOUT Competition!! By all means come and have some fun but a small amount of responsibilty would be good :) If you want in, PM me and ill send you the payment details.
Cheers
Brad
haha.. your setting yourself up there for quite a fall if the poosar does not come thru with the CHOP!
:P nah all harmless sledging ! hopefully I will get more goodies in the stagea before then
hey dale when you getting the swaybars in ? not THIS weekend ( broome ) but next weekend I am HOPEFULLY going to be doing my front swaybar install and maybe some castor bushes and hopefully rear subframe bushes .. but I am not holing my breath for that
Well, after the exemplary service i recieved from WA Suspensions (<--blatent plug in hope of sponsorship :D ) I am hoping to climb under there and get them fitted possibly this thursday. Castor bushes go in on Saturday and wheel alignment early nest week and then she will be all ready to dish teh chop!! :)
Sam, yes you can enter this event if you like, however THIS IS NOT BURNOUT Competition!! By all means come and have some fun but a small amount of responsibilty would be good :domokun: If you want in, PM me and ill send you the payment details.
Cheers
Brad
Hey brad i know i have taken my sweet old time but i put my payment in yesterday in morley i hope you can find it . Thanks Cory
Sam, i was behind u on the traffic light take offs and lets say u didnt just cruise off the line lol, and your overtaking of that 4wd and trailer in the pitch black out armadale or whatever suburb it was.
Good to see ya coming Cory, i cant wait to check out your car in person, its definately one awesome looking stagea :domokun:
now the big question do i come in 2wd or 4wd haha :laughing-smiley-014:
haha.. aah the race is on !!! the rear subframe bushes must be hand cut by elves high in the glacial highlands of newtopia because fck only knows where they are!
and .. I think I am facing disappointment for the swaybar to arrive today :banana: so looks like a weekend with no working on the car !
Well, if it makes you feel any better you can come and watch me install the swaybar to teh fury tomorrow afternoon :banana: (hopefully)
G`day all any luck with u bolt`s Dale ,cheer`s chuckie
Ill update this list today/tonight to mark confirmed payments etc.
If you have not yet paid and are on the list, you will have until the end of this week to sort it out. If not, i will have to take you off the list and offer the spot to someone else.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
