ok i cleand the inside of it out and tried again.. the engine seems to turn over, but doesnt start... I am only guessing that this thing is the problem, can someone confirm this before i start looking for this part...
if it is this at fault.. would all jap sell them.. if not, who else would?
I think i would only need the part that spins around, not the whole thing.
Originally posted by walkoau
its the variable cam timing unit. (i think thats what its called).
how the hell did the locating pin snap off?
you best bet is a jap wrecker.
how did i snap it off??
I realy dont know.. :confused:
I took it off to paint the cam belt cover with some left over paint from my boot lid.. I put it back on.. lined it up, and it slipped in perfectly, tightened all bolts,... went to turn my car on to move it back into a sunny spot to tack sum engine bay shots and the car didnt start.
thats the only thing i could think of that could go wrong.. so i undid it all to take a look and noticed the pin was snapped off
Originally posted by SteveL
It's the CAS = Crank Angle Sensor.    Not really clear what's broken off from the photo's.   Shouldn't be too hard to get one from a wrecker.  If you really get stuck I think I've got a spare somewhere, but I'm in melbourne.
the thing that is broken off is the little metal thing laying on the "cas" in the second photo. it broke off from inside the ??? hole :uh-huh:
Originally posted by dru32
so would this be the reason why the car wont start?
Yes...it tells the ECU info about injector an ignition firing points/crank position. Somethings obviously not lining up properly any longer. The internally splined 'shaft' engages with similar shaft bolted to the end of the ex camshaft. If it's not in the right position, then ign timing etc will be out.....
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
    • I remember reading that there’s a power steering pump from a modern car—possibly a Mazda—that bolts directly onto an RB engine and lines up perfectly, making it a great option for HICAS removal. Unfortunately, I’ve forgotten which model it came from. Does anyone know what vehicle this pump is from? Any help would be appreciated.
