just asking people on there thoughts of having a stagea as vehicle to tow, i know i used my r33 gtst to tow my mates skyline to mechanics when he broke down and afterwards it took me about 1/2 hour of constant thrashin to get my car back to normal damm learning computers ;)
question is stageas and towing car trailers with cars on it ie a 33 or similar wieght any good or am i just damaging a nice vehicle like the stagea
https://www.sau.com.au/forums/topic/200959-stagea-towing/
have a look at this thread http://www.skylinesaustralia.com/forums/To...html&st=100
even if you get the 2000kg towbar that doesn't leave much capacity after the trailer. my trailer weighs 540kg and is considered light. most rental car trailers weigh 7-800kg, leaving only 1200-1300kg for the car you're towing. not many stripped out race skylines weigh in at that, let alone road cars.
4WDs are the best (ie safest) things to tow with. If you are going to be towing car regularly, you should consider gettng a more suitable tow vehicle. My old GQ Patrol is rated to 3500kg towing capacity braked, as are most heavy 4WDs. lighter things like Hilux, Navara, Pajero etc are usually in the 2000-2500kg range. A diesel 4WD will also return much better fuel economy figures than a Stagea too. My diesel GQ gets 14l/100km towing - about what a Stagea gets just hauling itself around!
https://www.sau.com.au/forums/topic/200959-stagea-towing/#findComment-3574054
Your car needed to be thrashed? There is no learning in the stock ECU, the only thing is the low octane map if they detonate heavily, and that only resets when you turn the car off
adriano after towing the car for 20 mins , being an auto too (not sure if thatmade a difference) for a bit of time afterwards whenever you accelerated it would be slow to respond and the power output felt restricted ie you know when your missing a few g's a bit of constant foot to the slow soon leveled that out
and corect me if im wrong but doesn't the standard ecu have a learning system to it, from research i though it held up to the last 50 times you drove and setup the vehicle as so, so if you were a grandma driver it would give nice slow gear changes slower acceleration and better fuel eco, or if you thrashed it better response more fuel, not a huge difference in the vehicle however just slight
https://www.sau.com.au/forums/topic/200959-stagea-towing/#findComment-3575534
I've always thought cars do a bit of this although I dont think the logic is as complex as you might wish.
It'd just have a few different settings it could use depending on your driving style, things like different shift points etc. for the auto.
Can anyone confirm (someone that knows what they're talking about, not like me) ?
https://www.sau.com.au/forums/topic/200959-stagea-towing/#findComment-3575830
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
