Stock R200 Viscous LSD. 5 bolt halfshafts. 3.7 ratio, Non-abs housing $150
front and rear hubs with front lower control arms and uprights. $350 for the lot
Cobra recliner. Complete with Rail. Excellent cond, just needs a clean $420
A31 Cefiro electric seats (pair). Nice and comfy. $100pr
S13/A31 aftermarket springs and struts. Lowered 2in springs made by Espilor, matched with Monza heavy duty shocks (Made by Tokico). Also included are adjustable camber tops (worth around $200 alone) $550
S13/A31(sr20) whiteline swaybar. 27mm Non-adjustable complete with all brackets and links. $140
Yashio Factory Adjustable castor rods. $175
Adjustable Rear Upper Arms. Brand unknown but are Japanese items $175
Braided Brake Lines $160 set
S13/14/15/R32/33 etc Offset rear upper arm bushes. New. $75
Greddy turbo timer $80
Blitz Turbo Timer $80
Apexi Turbo Timer. $80
Turbosmart Supersonic Type3 BOV (x2). $160ea
TurboXS recirc BOV $150
Oil cooler kit with filter relocator- consists of BRAND NEW Justjap braided lines and fittings, and a 2nd hand Japanese Toyo Oil cooler. Will fit SR or RB (and probably others) $250 no offers.
Other Stuff
R32 GTST Lower control arms with near new nolathane bushes. No balljoints. $160pr
All parts in Campbelltown (Sydney)
https://www.sau.com.au/forums/topic/200974-fs-ceffy-parts/
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
