I've seen it done on a RB a couple of years ago, personally i dont know why you would bother with a RB, for the money it would cost, you can get greater gains for less money with a good turbocharger setup. It is different however and pretty cool to see people doing something a little bit different.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574748
i think when i look up supercharging on a skyline and read into it - it comes out expensive and lots of custom work
if you are a fabricator / mechanic then i think its fine - but for your average dude who just wants a bolt on kit turbo is easier and better $ for kw etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574868
yehi was thinking maybe turbo and supercharged, like some rallycars, my engine is already turboed and rebuilt but yeh i was thinkn to do something a little bit diffrent
Ah ok. Yeah a twin charged setup would be a good setup however extremely expensive to do and set up correctly. Would be interesting to find out how much something like that would cost. Has anyone in Aus ever twin charged a RB25?
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575494
yeah stockymcstock has done it he has a superchaged rb30det with a gt40
it looks like a complicated, lengthy and expensive process
do a search on some of his posts in the rb30 thread to find out what he has done etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575501
This is one hell of a set up :rolleyes:
http://www.403drift.com/gallery/galleries/...14mph%20run.avi :)
and the site with the build
http://www.403drift.com/galleryview.asp?ID=11
not a 25 but a 26, I have seen it in person and what a monster. Now this motor is in a R32 GTR cant wait to see a run on the track with that.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3576175
I dont think its fake it is in the same spot as the one in town and just has dual turbos. They created less lag but rob your top end
Not true...kind off. If those superchargers are twin screw, then they will not limit the top end power at all.
As for the pic, its been discussed before, and that particular thread came to a conclusion that it IS fake. Fake or not, its crap coz there is not way you can fit all that in a skyline engine bay :D.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577095
ask stocky, from memory he said it wasnt worth it. its alot of time and effort for not much results, just get a correctly sized turbo, and with the leftover cash go RB30DET
that pic of the twin charge kit isnt fake either, i thought it was at first too because the pipin looks dodge, but i've got a pic of it from another angle, and from what i can tell its real
the only thing with that is with the way the piping is (from what i can see) the system wouldnt work, as they are booth running in parallel not series, and there doesnt seem to be any sort of valving in line either, think they just threw it together to try and look good lol
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577329
i love suprechargers, they are a great upgrade on an NA engine.. hell i would love to put one on my V35. a guy on WA had one on his V35 before he sold it..
but for an engine that already comes out turbocharged, like the rb, it just seems silly to bother going with the R&D of a supercharger when you can just bolt up a different turbo if you're not happy with power. that alone is reason enough not to bother in my eyes
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577449
Very well said. Pretty much sums it off perfectly.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577642
    • Which would need the same trick wire routed from the aftermarket ECU to the OEM ECU's plug to make sure the aftermarket ECU won't power up when the OEM ECU is unplugged. Totally doable, just a bit of a pain in the butt.
    • The normal trick would be to leave the factory ECU in place, with a look on it (that eventually goes no where) and reroute the engines wiring to a totally different location, like under a seat and mount the aftermarket ECU there, and then make sure it's hidden.
    • Stick a Nissan sticker on the haltech?
    • Ozzie cops have known to look for aftermarket ECUs since the 90s. The only ones that could skate buy were bare boards that went into the stock case. If you then went and stuck a Link sticker or something on it, the loss of camouflage was on you. So, no, the new Haltechs won't solve any such problems.
    • Would the new Haltech Nexus plug-ins work for this? Or are they actually checking under the kick panel?
