hey there tom
how are ya man
its anthony here
from drift racing industries
just spoke to you on the fone regarding the pair of indicators
if you can send me your msn address
or add me if you like [email protected]
ok man
wil talk to you soon and keep in touch
cheers anf
  • 4 weeks later...
