Hi Guys,
I think the subject says it all but does anybody know where to get new rocker cover gaskets for a RB25det engine other than Nissan themselves? I rang Brighton Nissan today as I've been dealing with the guy there for years and he really looks after me price wise... well I hope he has, and he said that I'll be looking at $30.00 per side, there's actually 2, one for each cam but what I forgot to ask him was how much for the bolt seals coz they will also need replacing... no doubt.
I'm not to sure if the gaskets will come with the bolt seals but I'm guessing not... not 100% sure though meaning that there's about 20 odd bolt seals probably worth $3- $4 dollars each? it starts getting a little expensive! What do you guys think?
Does anyone know where to get new ones any cheaper with the bolt seals? Hope I don't sound like to much of a tight ass!
Thanks,
Gianni
https://www.sau.com.au/forums/topic/20106-common-r33-rocker-cover-gasket-leak/
  • 1 month later...
I don't think $33 is too bad. Mine aren't leaking at all, so I would think generally speaking they last around 8 years or more. That beats the hell out of Commodore gaskets which are about $10 but leak straight out of the packet :D
I paid $26ea from Unley Nissan here in SA. I re-used the original bolt seals, no prob's so far.... if you ignore the fact that No:1 ringland cracked :D unrelated of course.
Make sure it is leaking before you go to the trouble of replacing them...
Quite common to spill oil down the intake side when topping the oil up and over time the spilt oil will progress towards the rear of the motor looking just like a leaky intake cam cover gasket...
Clean the oil off with a rag and some degreaser and see if the leak comes back... Mine didn't...
If it's the exhaust side though, probably rooted gasket...
Just my opinion tho...
  • 3 years later...
Anyone know what the part numbers are? Also, would the washer be important. I cant find a dealer where i live that has the washers in stock. they've got the belts though.
I'd be keen on the part numbers as well, my r33 started to leak a bit if i dont let the car warm up...can this be done easily at home?? just unscrew the bolts for the rocker covers and replace the seals etc??
my rocker covers are leaking aswell "aparently" the other workshop i was at changed them... cops ass!!!
how much for gen nissan rocker cover gaskets, i also need a gen nissan exhaust manifold gasket..
therepost-17300-1160253786.jpg you go
Those aren't the part numbers you need....the Nissan parts guy will probably just stare blankly at you. It's much better to have the full VIN of the car but here's what to do:
- double click on the empty box to the right of the one that says 'Part No'
- enter the first three numbers of the 'Part Code' shown in your list....in this case 132....and hit return
- FAST may throw up another box asking which model/year for the car (but rocker cover gaskets are pretty common across the range so perhaps not). If it does you'll have to select (click on) the relevent car/year line in the pop-up.
- the full PN's should now appear in the main window, along with some other info.
Hope that helps
Called Nissan Today:
Rocket Cover Gaskets..
Part No. 13270-58S01 (1x Each)
Part No. 13270-58S11 (1x Each)
Washers (Rubber)
Part No. 13268-58S01 (1x Set of 20 Seals)
Hope this helps. Rob
Screen dump for you :thumbsup:
Oh and the price was about $30 bucks or so think it was $36 but under $40 each. They should have them for me by the next day :thumbsup: also found the part number for the rubber seals it comes in a set of 20 which will set you back about $2.45 each a full set is about $49.50/
Is there much to replacing them??? just unscrew the rocket covers and replace the seals?? obviously in a clean environment so no contaminants get in.
Cheers Rob
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
