Hi all,
My skyline has been up for sale, but its time for her to really go.
shes an R32 gtst Manual
1992
Blue with violet pearl
19" HP design rims with new rear tyres
Final Konnexion Bodykit
Front mount intercooler
K&N pod filter with heat sheild
Turbo smart Dual stage boost controller
Turbo back 3" exhaust with High flo cat
Turbo timer
Bosch 040 Fuel pump
High flo turbo (as ive been told) which runs 16psi all day every day
Whiteline Springs
Bilstein Shocks
Whiteline Adjustable heavy duty sway bars
Whiteline adujustable Camber and castor kits front and rear
Whiteline rear diff align bushes
front strut brace
Alpine stereo
front splits & rear 2ways
x2 fiberglassed in 12" alpine subs
Checkerplate floor
racing pedals
Impul gear knob
Autotechnica steering wheel
Autometer boost and airflow A pillar mounted guages
Full underbody LED mulit coloured light system
Timing belt done 12,000km ago
As well as new:
Radiator
Waterpump
iridium spark plugs
Clutch slave cylinder & master cylinder
Injector flush (good)
Serviced regularly and repaired by licenced mechanic
There is prob more, but cant think of at this time.
Beautiful car to drive.. qucik and fun.
Has to go.
Price drop $15,000
No joyriders, or waste of timers please..
Ph: 0402419988
or PM me..
Thanx
https://www.sau.com.au/forums/topic/201064-r32-gtst-for-sale/
Car? What car?
I'm with Mick: what car?
Seriously, sad to see another SAU'er putting their Skyline up for sale. What's in the pipeline, Andrew? Or would you rather keep it quiet? I personally hope it involves an RB26DETT...
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
