TOLL IPEC ARE THE WORST COURIERS I'VE EVER USED AND WILL NEVER USE THEIR PATHETIC EXCUSE FOR A SERVICE EVER AGAIN!!!!!
I do not under any circumstances recommend this company. I would rather walk to Sydney, pick up a toothpick and walk back to Melb than to trust this useless collective of muppets who couldn't find their way out of a jumping castle.
This is why I'm having a vent (sorry if this is the wrong place):
1. Product was ordered from a workshop in Richmond on Tues. The order went from this shop to the suppliers in Sydney yesterday 1st thing. The package was scanned out of Sydney yesterday at 11am. As of 5:45pm today (Wed), the package has not been scanned in Melb which could mean one of two things. Either the package hasn't arrived in Melb or they've lost it. I'm not happy with either excuse as they said it would be at it's destination by the end of the next business day which from what I can tell finished 25 mins ago!!
2. Another product was supposed to arrive from Qld on Friday. It didn't. They came round on Monday when nobody was there and didn't read the big note on the front door which said to deliver the package across the road. They took the package back to the depot and left a card. I then rang to organise another delivery time for this morning and low and behold, it didn't even leave the ****ing depot today. Even though they know it's in there, they won't allow me to go there and pick it up. They are going to get it out to me in the morning apparently. I'd like to see that!!
If I've learnt anything out of this experience besides Toll Ipec being a bunch of uncooperative, unreliable, highly overexpensive tools, it's that if you need something done badly, you either need to either do it yourself or find a trustworthy, reliable party to help you.
If I don't have all my parts by 2pm tomorrow, I doubt my car will be attending MAS.
Please help me pray that these parts arrive.
https://www.sau.com.au/forums/topic/20109-toll-ipec/
Guest INASNT
all couriers are like that, remember when my car was at ice waiting to get the cooler in, cooler piping was meant to be picked up from thomastown 10am thursday to be delivered to ice, they picked it up 5.00pm and it missed the friday sent out, so it got delivered monday afternoon, which meant i had no car for 5 days and this was only to be couried like 40 km's!:)
https://www.sau.com.au/forums/topic/20109-toll-ipec/#findComment-422186
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
