why do you want a cams approved one?
cams approved doesn't mean its street legal, any half cage is street legal aslong as the car is reg. as a 2 seater
edit:"note all j-spec brand cages aren't cams approved due to the thickness"
Edited by [Michael]
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3577011
Sam, your posting about your rollcage at 3am??? Go to bed and get some sleep man!!!!!! LMFAO
Anyway, try Maitland Fabrication? I know a guy with an early Zed, and he stripped the interior etc then gave it to them to build the cage. From memory he said it was about 2000-2500ish? That is cams apporved and not non removable side intrusion bars but under cams ruling, they can now be made removeable.
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3577430
for a decent cage thats CAMS happy for racing, your looking at 3k+ from most people, i recommend LF performance, maitland, and if you want really top shelf mark bourne, but expect to fork out big bucks..
do forget driving it on the road and A class rego tho, it won't happen, rally reg only for you
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3583662
mmm i think i might leave the cage idea for now, u dont need a cage for drifting at barbagello anyway, ill guess il have to try not to crash till i have more money :P
Or just get the half cage . . atleast its some protection
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3585483
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
