no info on here for rb25det
got- solid lifters and springs, rods with bearings, forged pistons
but recently some of u guys said i should upgrade my 256, 9.25mm cams.
im asking.. will 270..10.25mm plop straight in?
will i need modifying? prefer not to lol.
No. the head will need to be clearanced, some people will do it with the head on, but i dont.
mate if u can find the 10.25mm lift valve springs from tomei but let me know cuz i want sum aswell as the 10.25 cams and adjustable shim bucket conversion fron 25 head they claim they have all been discontinued
ECR33 RB25DET-
High lift camshaft could not be used for ECR33 RB25DET because NVCS oil pipe is running beneath the valve spring and it restricts the amount of the intake valve lift. Neither, could strengthen valve spring have been manufactured according to its construction. Now, we developed RB25DET special intake valve retainer that enables corresponding to high lift camshaft by 10.25mm, by enlarging the amount of valve lift. Deceleration of the valve can be also secured by applying strengthen valve spring, which is required for the high lift camshaft and high rotation of the engine.
and some info in here, down the bottom, may or may not be of interest, you did say you can't find anything much afterall.
http://www.calaisturbo.com.au/showthread.p...light=rb25+cams
so essentially wat does ne one need to fit theses biggish cams to an rb25 head..
yea...my thoughts exactly man.
y would they make them for a ecr33 if they CANT EVER be used??
so far we have: yes, but needs to be machined for clearance.
and NO, NVCS issues.
so has anyone actually using 270, 10.25mm lift cams. or similar big lift cams?
need help.
WHAT IS THE BIGGEST DURATION AND LIFT CAMS PPL HAVE USED IN A RB25, WITHOUT MODIFICATION (easily fitted)?
Edited by r33cruiser
thanks shanef such a damn relief- phheeeewwww..
well i have tomei valve springs and a solid lifter conversion.
so can i definitely run these 270, 10.25mm lift, without modification?????.. dont want to waste money
http://www.tomei-p.co.jp/_2003web-catalogu...m_RB25.html#pro
bottom of that page are the ones im looking at
u have to modify the head, u cant run that size cam without doing it
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
