Currently Im running a dual diafram clutchnet PP with 6puc sprung disk and a fidanza ally flywheel, thing shudders A LOT, its not a very nice formualtion they used for the disk pad's. For now it has been ok, land up with a very sore left foot and battle to pull away in the wet or up my driveway without chriping the tires.
I am not looking towards somthing with lighter clutch pedal effort, and slightly more HP capability to suit the new motor with around 400kw, Been looking at some twin plate's and from previous experience with the old school twin plates it leaves me with a sour taste, is there anything on the market you guys use that is not to brutal with shudder and clutch load yet can hold some decent power? Did a search but couldnt find anything useful.
The car is used on the street with very ocasional track usage, and the odd drag with fairly small M/T ET streets
Thanks
Thanks
tripple plate OS giken is the g-o, tuff as nails and they dont shudder
What is the pedal weight like? I need somthing that wont kill me in a little bit of traffic, I nengun dont sell them, any idea who does or rough price idea?
Take a look at the Nismo Super Coppermix twin plate, i haven't personally used it but from what i hear its very similar to a standard organic clutch in terms of drive ability around town and is rated for 600hp.
http://www.nengun.com/nismo/super-coppermi...in-plate-clutch
ATS carbon twin plate
is the stuff factory pedal soft just no slip
They are a touch out of my budget unfortunatly,
Looks like a toss up between the Nismo supercoppermix twin and the ORC 709, has anyone got first hand experience with the orc 709?
Contact jim berry in Bris. He made me an organic clutch for my gtr. done heaps of launches and a couple of sprint meets & hasnt let me down. easy to use in traffic & light under foot, doesnt shudder either.
People go overboard with expensive twin, triple & button clutches but it isnt required or practical for most applications.
It only cost me about $350 too.
iv got a orc 2win plate button, its light under the foot, a lil noisy when u step on it, but takes a long time to get use to and not the best on hils or ups n downs or TRAFIC. in fact its real bitch to park in tight spots but u get use to it how ever i always avoid trafic even if it means ill just sit n have a drink till 6 .. not worth the head ache..
might try the nismos next to see..
  • 1 year later...
I had huge problems in my old 33. Went through 2 exedy's under wty then gave up. My old man who is a mechanic got me onto somebody in lismore he has known for 30+ years that did an awesome job on a nice single for me. Held my 345rwkw no problems no matter how i drove it :)
Have a chat to Dave Write on 0266216495. Best thing i ever done. Cheap, quick and he said he builds a few big hp skyline clutches for a few workshops in sydney
Edited by coaster
I'm using an NPC single to hold around the horsepower you are looking to make. Pedal weight is as light if not lighter than stock. Its a bit sudden but quite easy to control once you learn it.
Kills the berry single I had prior to this. Berry clutch was just as grabby but way heavier pedal and with less clamping pressure than the NPC.
been more than 18 months now since I went with the Nismo supercopper mix twin plate, best clutch I have ever used! and as with all things car I landed up with 150kw more than antisipated in the power department... The Nismo clutch feels no pain when the T04z is at full tilt.
I stripped it out last week to change the N1 oil pump, clutch after 20 000km's of abuse still looks like new. Still running as smooth as stock and the only con is a tiny little bit heavier than stock clutch, probably within 10%.
Sounds to me like you've answered your own question. :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
