i have a electronic boost controller (Greddy Profec B Spec 2), and the cars pretty much stock except a cat back exhaust. im having a top boost of 11psi but it drops to 8.7 nearby redline. what do you guys think the problem is?
I don't think i have any boost leak as i dynoed it to check and the unique auto sports guys says its normal for the stock turbo but they also said a cat back exhaust will help the boost drop less, but it didn't do that.
What do you guys think the problem is? i really want a full 11psi boost to redline.
by the way the car is GTT R34
Edited by 10MinuteCar
wait im so newbie that when you guys always say front pipe i don't get what it is. i know the dump pipe is the single pipe from turbo to the cat but wats a front pipe??
dump pipe is straight off the turbo, which leads into the front pipe which is just before the cat. aka dump/front pipe. u can get it in one peice.
do everyone drop 2 psi on higher than stock boost? even with a eletronic boost controller as well like myself?
I use to have a case where my rubber intake collapsed causing the boost to drop once the engine bay was warm, and with the silicon intake pipe I purchased, IT MADE IT WORSE ended up going back to the stock intake, and reinforcing it with stainless steel off cuts. Problem solved.
I think the reason why your boost is dropping is due to your restrictive exhaust system. Invest in a dump & front pipe and a high flow catalytic.
My 34 drops boost by around 4 pound on redline, i have the boost set to 14psi and by redline it drops to just below 10psi, get used to it mate if your going to keep the stock turbo
It is normal, altho mine is dropping from 14psi to about 11psi
get a free flowing full exhaust system as suggested before to help it breathe better
i would of thought that standard turbs would be able to hold 11psi but i guess not
is it possible to use a r32 actuator inconjunction with the EBC by any chance?
Yes but you would be wasting your time, I have a adjustable hks actuator and it still drops off boost
just a question ;) would a exhaust manifold leak cause the boost drop as mentioned before from about 11psi down to 9psi as well? or will it never even reach the 11psi in the first place?
Possible but it would need to be a big exhaust leak
I just had my leaking manifold repaired.
Problem was low boost from low rpms. Once i put the boot in it was hard to notice because there was lots of pressure and i made the 11psi my boost controller was set to.
Manifold leak (depending how severe) shouldn't cause high rpm boost loss. Like all the fellas said, it's normal for your setup to lose 2-3psi.
I run a GReddy profec on my GTT also and have found that just playin with the gain setting in particular can help stop the boost dropping off in the higher revs. Im only running 10psi hi boost and still playin round with the settings but have managed to get it pretty good and hold the 10.
I also have a 3" system off the back of the turbo that prob helps a bit too tho.
Good luck!
Good luck!
oh great! since we're both using the same cool EBC :P could u gimme some advice on how to set the settings to hold 10psi boost please? from 1st step to last as ive never tried to touch the EBC myself but will do with the help of a pro :D
LOL i am hardly an expert!
Ive only had it on there for bout 2 or 3 weeks and been playing with it tryin to get it somewhere right.
just went and had a look at my settings and atm they are-
set: 40%
gain:27
set gain:6psi
its holding boost pretty well but needs more fine tuning. also been hard cause ive been trying to do it on my own...
My cars mods are just 3" turbo back and a K&N panel so pretty stock...
hope that was of some help to ya! :P
oh also just adding the peak boost with those settings was 10.3psi....not sure of the rpm(bit hard to drive and look at it lol)
Edited by jase-r34
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
