LOL i am hardly an expert!
Ive only had it on there for bout 2 or 3 weeks and been playing with it tryin to get it somewhere right.
just went and had a look at my settings and atm they are-
set: 40%
gain:27
set gain:6psi
its holding boost pretty well but needs more fine tuning. also been hard cause ive been trying to do it on my own...
My cars mods are just 3" turbo back and a K&N panel so pretty stock...
hope that was of some help to ya! :P
oh also just adding the peak boost with those settings was 10.3psi....not sure of the rpm(bit hard to drive and look at it lol)
Cuz ive got it installed and set by UAS, i didn't really wanna touch it so before i do this how do i check wat the original settings are currently? what do i turn or press on the EBC? :D thanks alot by the way
to check the set just turn the nob but dont press it in...it will display the current setting and go away on its own.
for the gain just press the mode button once, press it twice for set gain, and all the other settings are the warning and limiter and peak boost etc...
let me know what they are set to atm and what kinda boost ur getting...
:P
Set: 45%
Gain: 20%
Set Gain: 8.7psi
Those are the high boost settings which makes around 11 psi boost like 10minutecar and also drops as much as he does (to about 9 psi)...
Do the other settings affect the boost or performance wise at all or are they just extra features such as warning alarm and etc?
Also does the setting you have spike boost at all? And if it does spike the warning alarm will go off right?
Edited by R33Turbo
I havent even been in my car since yesterday so nah havent tried em out yet. It sucks in the rain i get to much wheelspin in second gear...
With the warning, i have never hit it as ive been conservative with my settings as not to overboost.
But yeah according to the manual the warning light comes on and the unit will lower boost by whatever you set the limiter to.
so at this setting u gave me it reaches 10.3 psi max?
If i wanted to reach about 11 psi with the boost not dropping below 10psi..how would i set the settings? im not too sure how to do this percentage setting thing
what i would do is just turn the knob up a couple of % at a time. dont forget u gotta press the knob in to actually set it.
just dont go upping the gain or set gain too much. It should only be adjusted up like 1 increment at a time....at least once its close to being right anyway
Have you gone for a run with those settings tho??
It probly is.... like i said im still playin around with it and have only had it for a couple of weeks... ill give ur settings a go tomorrow and see what happens.
It was hard for me to tell if it was dropping off much as i couldnt look at the guage as i was driving and was only relying on the peak boost and last boost features on the EBC.
If the boost is dropping off try increasing the gain setting by 1 or 2 increments at a time. just keep an eye on the peak boost. its a good idea to clear it before trying out new settings.
Where abouts are you from?
Yeah the last boost tells ya what it was as u let off the accelerator, not a drop in boost. I really just need to get a mate to come for a drive with me so i can see whats happenin. Like I said before ill try out the settings u mentioned and see what i get with them...
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
