Hey guys, I recently found that the BOV return pipe on my R33 had a bit of a slice in it. Well, the hose bit anyway.
Where does this pipe return to the inlet? I am assuming that it returns unmetered as it already has been.
This would cause the car to run a little lean right?
:rolleyes:
Edited by Finchy33
https://www.sau.com.au/forums/topic/201181-leaking-bov-return-pipe/
it will cause it to run rich, because the air escaping has already passed the afm and it thinks the air is going into the engine.
I don't think it would be causing too much of a problem, as it would be the same as if you had an atmo blow off valve.
