Another reason they can blink fast is iff you replace your blinkers with smaller ones like i did it lowers the resistance and the flasher unit thinks there is a blown globe you either need a different flasher unit or wire in some larger globes like i did
I'm not sure if this is relevant but when I disconnected the front indicator/foggy connector
and turned the indicator on, though there's no light but the interior dash indicator indicator flashes like crazy
i think its the same situation where if a globe is broken you have broken the curcuit so if a globe is removed the curcuit is broken too? not 100% if that correct though..
^ yep, broken curcuit will make it flash faster too. i recently had this happen after putting my front bar back on. i thought it was a blown globe, but actually it was making poor contact in the holder. cleaned it up, problem solved.
If you havent changed anything then its going to be a blown globe.
i know it started with mine because i put smaller indicators into my front bar as i hated the big ugly orange ones.
i dont mind them flashing fast but does anyone know if its illegal?
Could cause people to have seizures(sp?). So would say that it's illegal.
there is a legal rate that all cars in australia must flash between, cant remember what it is off the top of my head, fairly decent size range though, also on my 32 i noticed it doing this, stupid thing has 2 blinker globes in the corner lights, took me a while to relalise
I've got this problem of having them go fast one day and normal the next. I think there's something loose.
I get this on mine from time to time. Turns out there's a water leak letting drops of water into the socket for the rear lights and causing a short. Once it dries out, it all works fine. When the rain stops after a wet period, I usually spray some electronic cleaner in there which evaporates the water real fast...
Might be something else on yours though.
Ok yesterday I took out the Amber lens after heating it in the oven,
put in some orange bulbs and glad wrap over the indicators (just a temporary solution)
connected it back up and today my indicators go like crazy, everything is working
but the indicators are flashing like 3 times a second.
It goes back to normal when I put the emergency lights on.
Any ideas guys?
Edited by POLICE
Hrmm, cheers for that mate. I'm gonna keep an eye out what happens after a down pour.
