Hello
I posted a this post in the wrong area again, sorry but here it is.
I have a R32 GTS-T and I live in Japan.
I have to replace my front rotors. They were turned once, but a lot of metal was taking off because the rotors were warped.
I want to buy slotted rotors but my friends(some own skylines) tell me that slotted are good only for racing.
This car is my daily driver, but I would like to go to the track maybe once a month once I get the mods done for my car I want to do.
Are slotted rotors fine for everyday driving or should I get after market stock rotors?
Help please!!!
THe slots vent off gases that are created by the brake pads and rotors rubbing on each other at high speed and pressure, causing a lot of friction and heat. Its meant to reduce brake fade etc. They are fine for everyday driving, but if they cos much more than standard rotors i wouldnt bother as its not going to make any noticable difference in normal day to day driving. If you are going to do a bit of track work then yeah go for it, but a set of better pads will make more of a difference (greenstuff etc)
I have good brake pads on there, but wanted the slotted. My friends said it takes away from the braking surface and not as good as stock for everyday driving.
I can get a set for about 200 dollars vs 110 dollars for a set of stock.
So stick with stock?
Edited by 335
the slots are about 2-3mm wide.... considering how fast ur rotors spin as you drive the difference in braking surface area is negligible. Id probably run slotted, if ur doing track days often, but for the sake of $90 just depends on whether u can justify it or not. If ur getting work done on your car, there will no doubt be a car there that has slotted rotors. ask the owner if it made a difference.
Ok I will check more. I know that everyone I speak with (some of the guys have GTRS and modded R 33's say that rotors with holes are bad because can break more easier.)
The slotted rotors I am looking at are not holes in the rotor but just slots cut into the rotor in a few places.
Should I replace the back rotors too? I don't think that they are warped, have to check but want to know if case a good idea.
Edited by 335
the ones with the holes are cross drilled which yes i have seen many times they fracture and crack, i wouldnt bother going cross drilled for street... i run dba4000 slotted on mine and they are great
hey guys,
on this topic. so which one is the better one?
RDA or DBA?
i have got a friend who has a slotted RDA rotoe on his car with stock caliper n using endless brake pads(not sure which one). what happen is that his rotor is thinning out (slots are less) the mechanic says the rotors are sh!t and the brake pads are too good for it. tats y the rotors are thinning. his car is not a high performance car. just a ek4 civic. the rotors only lasted one year ( brake pads are more than half used )n he got to change the rotors.
shed some light please....
cheers!
hey guys,
RDA or DBA?
cheers!
DBA's are generally a better rotor, but at the end of the day its relative to what you want to pay.
I use Endless CCX pads which are most likely what your friend is using too. I do track days with those pads and standards nissan discs (i keep them in on the street too) and they are lasting out fine....so that might tell you something about RDA.
Just by the RDA rotors - they are significantly cheaper than the DBA ones & about the same quality (Not very good). There is a group buy on SAU so have a search for that & save yourself some money.
As for pads if you are predominantly using the thing on the road stay away from pads like the CC-X. Get something that works from cold. Otherwise you could end up in a nasty accident - ie running into someone because the brakes are still cold & you can't stop.....
What brake pads do u guys reccomend beside the cc-x?
just for street and maybe some track days??
ebc brake pads and endless seems popular.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
