Ok
Before I buy this used RB 20 DET turbo to replace my dead one, what if I put on a RB 25 DET turbo? I read that people have done it but no one mentions if they had their car tuned afterwards. Do I need to tune if I put on the RB 25 DET turbo? Is it a headache to do this? alot of extra parts?
Will it be more than 10% laggy than stock turbo?
Help please, we be buying a turbo tonight or tomorrow.
https://www.sau.com.au/forums/topic/201265-hmmm-rb-25-turbo-onto-rb-20-det/
You need a tune (ECU required). Simple as that.
It will be laggier across the board than the RB20 turbo... afterall, it is bigger.
Ok Thank you. Is it worth it? Will having after market cams or cam gears make up for the lag?
Edited by 335
Hello
Thank you
I read that, but what is a banjo? and do I have to buy a new exhaust manifold? If so, what kind? Will the RB 20 Det gaskets match up to the RB 25 turbo?
Hi mate, I just did this upgrade so I thought I would reply.
First of all, all you will need for the RB25 Turbo upgrade is the Rb25 Turbo + Rb25 Turbo elbow, thats it. Its a simple install, and if you are planning on putting a turbo on anyway I would suggest going with the RB25 Turbo if you can find one at a right price. People talk about an increase in lag, and while this is likely to be true due to the increased size, it is not noticeable. I feel that the benefits in power far outweigh this anyway. It is definitely worth doing.
Oh, and I don't know about tuning the car after doing this upgrade. The most I did was an ECU reset. Don't know if it did anything but I did it for good measure. The car is running fine after the upgrade apart from an intermittent idle issue, but I don't think it is related.
Edited by Hydroxinol
I can get one for 150 dollars but I cant afford to get a computer and have the car tuned, so I want too but if have to tune it, I cant afford it now.
Can I run it safely without tuning?
Yep definitely, as I said mine has been fine. I am not 100% sure about this but I would assume that the stock computer would compensate for the increased air flow. So a tune may not be necessary. But I would wait for someone to confirm this as I am not positive, i'm still learning :P
Yeah you can run it safe without tuning the std ecu will just more fuel in to compensate for the 7% or so more air going in, it usually over compensates and you will get fuel smoke on boost.. just get it tuned later down the track.
Edited by RaZ_TuRbO
Don't forget you need to have a pressure tapping point (for your wastegate actuator) from somewhere. The r32 turbo takes its pressure off the turbo compressor housing. However the r33 turbo i believe takes it from the line after the intercooler (which you wont have). I was planning to do this mod and so have a pressure nipple threaded into my compressor elbow.
I will be advertising an r33 turbo and elbow for $200 soon if anyones interested. Elbow comes with a pressure nipple attached already. SO your basically good to go.
While i'm here...i beleive the banjo bolts have to be changed if your car is BASICALLY an early 1989 model i think. Mine's a 1990 model and i measrued the banjo size and they were fine.
yeah only with the year difference you may have banjo problems... as my cefiro 1990 had different size banjos compared to r32 turbo when i upgraded (and to hks 2530 & hks 2540 & now GT3076r) i changed to banjo's to suit, and the standard 32 ones (later model suited all my upgrades).
Edited by huddy
you can run the 25 turbo with the stock ecu no worries, just dont expect the performance to be much better then stock... there will be more lag also. for the BEST gains, remap the ecu and tune to suit. then the car will perform a LOT better and you'll wonder why you didnt do it sooner rather thenw asting time with an ECU reset :(
Hello
Mine is a 91 so I should be fine?
I have a choice of buying a used RB 20 det turbo or the RB 33. I need something but dont want to get the RB 33 if I have to spend alot more money to have it work. Both are the same price.
I have to decide today.
Which choice is the best?
More than 10% lag over stock? yes.
Need a remap/ecu? no. It would help with the extra lag but not needed.
My RB20 made 183rwkw with a 25 turbo @ 12psi untuned and definately went better than the stock 20 turbo on 14psi. The only thing I would say you NEED is to make sure you have a decent fuel pump (I have an 044 intank).
Get the RB25 turbo over another stocker mate, easy upgrade and will be fine - just pay attention for knock when you're winding the boost up, 12psi was all I could run untuned without dropping the timing back which would make the offboost even worse.
Ok, thanks for the heads up. I don't have a fmic or boost controller yet, so if this is a safe bet, then I will probably go with the 25 turbo, just don't want to damage anything else, having a turbo die was not good.
So this nipple thing is the thing I really don't understand. I guess if I had a fmic, I would probably have the nipple already on the piping, so since I don't, where would I add this so called nipple? And what does the RB 25 turbo elbow look like?
Get a fmic asap or at least an r34 smic, your stocker is going to heatsoak pretty quick with the extra air and will be restrictive too.
As for the nipple, stock RB20 turbo's have a nipple on the compressor housing, this is for a vac hose to the wastegate actuator. Any boost source will do (before the throttle body) but best to put it as close to the compressor outlet as possible :P
The elbow is an alloy 90deg elbow that bolts to the turbo compressor outlet, 25 item is bigger than the 20.
SAFC would help but to get the best gains you need to adjust timing in offboost areas.
Another thought, preferable to get a s1 25 turbo with the steel front wheel, the nylon compressor wheels really don't like extra boost.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
