  • 1 year later...
hey im planning on doing the same thing. Ive got a 89 gts-t and im concerned about the "banjo's". What exactly is it? Will i need to change it? Also, will i need to change the turbo gasket?
Also, i heard the s2 rb25 turbos are slighter better than the s1 turbos because they got a nylon compressor wheel, is this true?
Edited by IM-32-FK
The "banjo" is a fitting that is like an O with a bolt that goes through it.
Series 2 turbos are supposed to spool slightly faster due to the nylon wheels but I've found they like to delaminate when too much boost is wound into them. Series 1 turbos seem to be able to handle more boost.
