Hey guys,
Pleased to say I picked up my car today (Saturday). 2000 Stagea RS Four V. Interior is very clean, has the wood trim, leather and electric seats, proper floor mats, dual sunroof, triptronic auto with optional?? steering wheel shifters and got 18x8 BBS Rims (looks like the RX Monoblocks but not sure - maybe someone can confirm). Paint is pearl white, bodywork has a few minor nicks and a blemish on the drivers side front quarter panel (hopefully with a full detail can fix it but if it can't oh well). The importer had this or a silver one but the silver one has a factory TV and cloth trim but the clock says 68,000 but the engine has really done 151,000 where as my one has done 100,000 with full service history
Will post pics of the car when there is daylight
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/201268-new-stagea-owner/
Hey guys,
G`DAY JASON GOOD TO SEE ANOTHER STAGEA ON THE ROAD HOPE YOU HAVE A BALL WITH IT ENJOY YOUR MOTORING DUDE,LOOKING FORWARD TO SEEING SOME GOOD PHOTO`S,GRAET STUFF DUDE CHEER`S chuckie.
Welcome to the Stagea Gang......
Another Prime edition.... nice to have all the extra's, (well I think so)....
BTW the steering wheel controls for the tiptronic are std in all series 2 cars.
Still a very special car, you'll enjoy it, for sure.
i want your rims!
Very nice car.
Sorry Ryan can't have 'em lol
One thing that I still can't believe is how quiet the car is. Had my best mate test drive the car and I couldn't hear it flying down the street. Now I'm going to install a 3 inch cat-back exhaust (got a 3 inch cat-back exhaust from a skyline sitting in the shop that would defiantly need modifying to go in my car)
Also I'm going to lower the car (set of King Springs - CBF for something like Tien Super Streets, I don't see the value for me). I'm thinking around 1 - 1.5 inches all around. Reckon that will look good and would that be legal in terms of ride height
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
