since i've had the car the passenger side window on my 32 4 door has always rattled, i've tried previously to remove the trimming, but get to a stage were there is something holding the trim in, after undoing a number of screws i can see, is there anything i need to do to take this trim off that a dont know about?
and/also any ideas on wot has come loose off my window/rails?
https://www.sau.com.au/forums/topic/201304-window-rattling-passenger-side/
i just went out and check my doors (32 4 door) There is a little plug underneath the handle that you clip out and there is a screw behind that, then there is 3 along the very bottom of the door... and i can't remember but i think if u pop out the power window switch there is a screw in there too, then pop out the surround around the handle to open the door on inside .. it just pulls out...
then pull on the trim from bottom first.. it will come out and u will sorta have to lift it off cause it clips over the door at the top. Both my front windows rattle but only at certain heights...
If you figure it out. Let me know what the rattle is.. it drivers me crazy
