Dont forget to take your keyboard when you go 'see' his 'mate'.
You've been warned. Personal threats will not be tolerated.
i wasnt threatening anyone... it was just a friendly f**k you dont call me a retard
What size cams and what headwork are you 'planning'?
That Tomei stroker kit is only the 8 counter kit and the 'cooling channel kit' is actually only an extra option regarding pistons. Everthing else is the same.
Do you actully need a stroker? Plenty of guys are running rb26's with TO4Z's and are making the required power.
technically no i dont need the stroker kit but with the extra displacement which would provide more torque with the longer stroke and so forth you know where im coming from....
u have for sale it says an 05u block with hks 2.8lt stroker bottom end was the o5u bit stand for
head work im not really sure i still gotta speak to sum ppl about where i should start and wat is need as such
ummm 270's with _____lift was my first choice but im not sure if i could go for a lil bit bigger in the vacinity of 280's theres biggish but yeh im just unsure at this point
plus call me a dick but ya cant beat the cammy skyline note gotta love it
Edited by skylinekid
oooww - feisty thread!
...ya cant beat the cammy skyline note gotta love it
Hell yes ;)
280's are massive on a small capacity import motor though. What ever you do decide, make sure you do your research. Strokers, cams and turbo clearly dictate the nature of the car when done. With only two driven wheels, your planned use for the vehicle needs some good thinking.
Tis the code given to the normal, run of the mill RB26's. I.e. not N1 or GT block. Theres some good info on SAU regarding this.
Edited by GeeTR
I have the tomei stroker hidden in a GT block.
Turbo's are HKS GT RS's with Tomei Procams 270 @ 10.25mm with a ported head.
Fullboost (1.65 bar) @ 4800 RPM in 4th (give or take 100 RPM)
Wouldnt change a thing. At times i wish i had maybe 2530's but it really isnt that bad.
personally i would be pissed with that kinda boost response....
try 1.8bar at about 4000rpm in 4th from a 2.6l with no head porting and a t04z
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
