  • Replies 607
Posted Images
Does anyone know who owns the white R33 with plates "YCOPY" ??
I was cruising behind him last night on way home in the back of ingleburn it had a sau sticker on the rear window
Nah sorry Jess never seen that one before i work in ingleburn industrial so im around ingleburn area all the time. All i seen is purple r34 GTT with black bonnet, white R34GTT, white r33 gts-t kitted up, black r33 sleeper and a gunmetal 32 GT-R. Half always like to give a bit of early morning stick past my car over the bridge for some reason. I guess its to much exitement to see another skyline and cant help them selves. So yeah im guessing this "YCOPY" might be a noob.
Got room for a family of skyline admirers? new to the forum, interested in meeting some people from SAU.
i drive a POS and ill park at least 100 meters away from your Rides i swear...
:yes:
Southern/Campbelltown Meet Up = SOCAM
Hmm just a thought.....
Edited by OMG 101
So how is the weather looking guys for saturday??
So does everyone like chocolate cake?? :laugh::D
I'm actually getting excited been ages since I have had a nice picnic/bbq...*memories* lol :)
weather for sat is sayin isolated showers on the coast, don't know when in the day but?
chocolate cake is good :D
i'm keen as i can't wait just want the week to be over, hopefully it all goes to plan :D
course i can twit. we have had this converasation before. im home thursday and friday if anyone wants some tinkering done for the weekend ie your boost controller dave
Wicked im home thursday friday,ill be around for sure and ill bring the EBC and tail lights,bring on the boost!
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
