See you all Bright and early at the meet point at 9amish...
Please don't be late!
Ill be be up bright & early, about 4.30am probably! :/
I wont be in my skyline unfortunatley havent got it back from the workshop yet! :P
see you in the morning! ;)
  • Replies 607
Posted Images
Well that was a excellent meet!!
Thanks to everyone that came :) Was so much fun doing the GP Challenge!!
Results for GP Challenge Last session
1st Dan
2nd Liam
3rd Joey
4th Paul
5th Jay
6th Jess
7th Kiel
8th Jeff
9th Jordan
10th Sana
11th Sam
12th SABA
13th Mel
14th Lauren
I came 6th all up :banana: in a grid of 14..and very sore the last kart I had was so heavy on the steering I will be feeling it tomorrow
Thank you to Joeyz parents for putting in the BBQ after..was yum!!
I will scan the results and post them up Monday Guys :)
So what are we going to do for April??
Hi Anna and Marko R1 :D
Welcome to the forum
Yep like Jazzy-i said, we have a meet up every month, we have done cruise and dinner
Last one was a BBQ at Shellharbour and March was a Go Kart GP Challenge in Picton :D
Always open for ideas and suggestions on what we can do for each meet??So start thinking guys and we will vote :)
I suggest for April we have a cruise and end it somewhere having a nice dinner or Lunch..
I do like a nice Sunday Cruise..Maybe Kangaroo Valley if most are up for it
Hey hey.....any peeps wanna lend a hand ripping out my motor?? Finally get my car up and running only to spin a bearing yay :worship: Anyone have space for rent so i can pull my motor out?? Heeeeeeeeelp, i dunno what to do.....
What happened to coming round Jeff?? Lol, all good, i been smashed with the flu all weekend. Gimme a buzz if ya wanna come check out da crazy noises next weekend :)
Sorry missed you all on saturday,
I had a points score round with SSCC so had to do that instead.
No problem bout the crane and stand Dave
Like jess said her engine is now out and completely stripped down so shes bought a few nice bits for it.
Hopefully will be going back in next weekend then you can grab the crane back again till your done with it.
hi sinful - i vote for Kangaroo Valley (lunch) the longer the drive the better :worship:
while on the subject of pulling out engines...my brother has an r32gtr as well but his turbo's are gone (been off the road for 4yrs)
how hard is it to pull the engine out? he has access to an engine stand & a big garage...ive heard its next to impossible getting the turbos out whilst the engine is in the car
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
