My car has problems turning over when the motor is warm. On cold start it will turn over fine and first go. IT has a bosch 040 pump in it which has been flow tested and everything appears a ok. Everytime i start the car i prime the pump for 3 seconds or however long it takes for the whine to stop, in the morings it is fine, along with starting after leaving the car for a few hours. However the problem occurs when i have been for a decent drive, then switch off the engine and come back to the car about hlf an hour or an hour later. Pump primes as per normal and the car cranks like normal but it doesn't want to start and cranks for about twice as long before the motor then tries to start and then splutters off. Turning the key again at this point and it will start no probs.
This issue seemed to have arised after the bosch pump went in, so at first i was convinced it was something to do with the pump, but i have since had the pump looked at and tested and everything seems fine, that car also holds fuel pressure fine when driving. So the problem appears to be a combination of heat and time. My question is what could be causing this to happen? A shot sensor maybe? what sensors would be associated with startup? Could the fuelline be affected by heat? I'm really struggling to work this one out, cos it only happens afte the car has been driven for a bit then left for about an hour or so... :P
Any idea's??? anyone has simular hot start issues???
thanks heaps for any help
Jordan
Edit: Replaced the pump and it fixed the problem, turns out the pump was the issue all along. :D
https://www.sau.com.au/forums/topic/201345-hot-warm-start-issues-r33/
The only time I have had similar problems was a track day at EC in 38 degree heat.
Just heat soak or whatever its called. However though just with your normal day to day driving, yeah Im stumped!
Fuel lines get too warm/hot?
Has it only been happening now, i.e. summer?
It has been happening before summer, as in it would happen even when the weather wasn't as hot, but summer has definately made it more noticable / frequent.
i had the same sort of problem with my ca... i assumed coils were cooking under the cover! now having 20 year (or there abouts) old coilpacks u would think they are pretty shagged! i took the coil cover off to release the heat! doesnt happen so often now!
Yeh tried taking the cover off and made no differenence unfortunately
Plz I need idea's / answers...
Take car for a decnent drive. Park, return an hour later, prime, turn over and er er er er er er er er er er er - starter motor, and wont turn over, try agin, and it will start straight away...
What the hell is wrong with it!! :)
are there any other mods done to the car? have you every had the engine out? any conversions etc?
i would start with coilpacks personally, splitfires can be had for around the 480-490 mark these days, and if you were having problems with misfiring before maybe you just need a new set.
What battery is in it and how old is it? Maybe try measuring the cranking voltage with a multimeter to get a rough idea how many volts the bosch pump is getting whilst cranking. Its pretty suprising with older batteries and efi cars, sometimes they seem like they are cranking over strong, but really the cranking voltage is too low for the ecu to work properly and get the car going, i had simular problems with my r34, new battery and presto.
Mods are Power FC, full exhaust, fmic, pod, boost controller, bosch pump. car runs fine and makes good power. 202 kw 11.5 psi
I changed the battery over last yr as the old one totally died. I haven't suspected the battery through cos it cranks quite fast, whereas when the old one was going it was getting slower and slower, but like you said maybe its still worth checking as could be decieving. But that said, I'm not sure what the battery would have to do with the heat - cos it only struggles about an hour after a drive... Could coils heat up more when the car is off and not function properly on startup?? could plugs be an issue? I dont have any misfire though.
Also the engine has never cutout whilst driving, and is not a conversion or anything. Car runs perfectly smooth when started, just struggles to turn over when the motor is heated up after sitting there for a bit..
And speaking of coils, anyone know if I would have to change the plugs or get anything re-tuned on the pfc if i put splitfires in? atm the plugs are gapped at 0.8.
thanks
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
