32gtr
gtrzilla
 Share
i couldnt imagine a stock car like mine having an engine go bang without any mods
sure general maintenance will be required but after all, it is an old car
then again
you would expect a rb26 to be a tough motor
hence maybe i will take out the boost restrictor
but i should probs do an exhaust for this
i
It is tough but detonation will kill any motor
Give it the right conditions (shit fuel, clogged injectors, 18 year old fuel pump, 40 degree + days) and youre tempting fate
yeah the compression is pretty low, should be up to 160psi, and 120 is the low acceptable limit in the workshop manual.
but that assumes it was all done correctly:
engine warm
all plugs out
throttle open
good battery charge
and that your gauge is accurate.
generally, as long as the readings are fairly even (and those ones are) then the actual readings are less important.
Im with Duncan, compression numbers generally dont matter so long as they are all close. And they are, so i think its safe to assume your ok.
Its the same with dynos. Peak power doesnt mean a great deal as it varies from dyno to dyno. I tend to try stick to the one dyno and go for gains rather than peak.
For example, my old Integra Type R made 136fwkw with a cold air intake, stock everything else.
Later at a different dyno with the addition of Mugen 4-1 headers made 120fwkw... Then again, on the 2nd dyno shop with the addition of a Mugen Twinloop catback and de-cat it made 133fwkw.. gains FTW.
EDIT: That compression is shit too.
mate
i dont see what your basing this on
and im sure the proprietor of RE knows more about engine health.
along with the rest of the members on here who are actually writing useful information!
like some of the others have stated, get a full service done first (oils, timing belt, water pump etc) and put on a descent 3" cat back exhaust and high flow cat and pod air filters. these wont be putting too much strain on the engine (or turbos)
also how does ur intake plenum look? alot of paint flaking/missing ? or is it all completely black?
ps. congrats on the purchase, hopefully mine comes soon :|
yeah
that was something i was looking out for
the intake plenum has very minor paint flakes up near the back, as i said very minor tho
and no real indication to show it has been re painted
Edited by gtrzilla
You don't sound convinced on mods. You obviously want a mild GT-R (which is still excellent!) so leave it at exhaust/intake/ECU and remove the boost restriction is my thought on that.
Otherwise i'd fork out some decent cash (like $1000+) on some heavy servicing because it's an old car. If you want to avoid a rebuild then spend the time/money to freshen up the engine, drivetrain fluids and other worn parts (oil/water pumps and things like brake rotors/lines, suspension, clutch, belts).
I'd spend big there before modding the car, if at all. The car will run better and do it for longer too.
Stronger car = safer mods
Have fun!
Edited by R338OY
Another thing i could suggest is whilst doing the timing belt(and tensioners) is pull the oil pump off and loctite the bolts that hold the two halves together. I would do as you suggest and leave the boost down. When you want to turn it up, get some steel wheel turbos and a remap
 Share
    • I speak from experience, because my driveway is DEFINITELY not flat, and all 4 corners of the car sit completely independently from one another. It's bad enough it makes me guess everything, fender flares being the most common example, every single tyre sits different in the guard. I've learned to just go OH WELL and pretend not to see it and assuming it's fine. That said, unless you see your car on the alignment machine to soothe your brain you may forever also suffer this pain lol
    • Thanks guys, I wasn't trying to dial in any kind of accurate alignment, I was just trying to stop my guard from shaving my tyre. Can't tell you how often I visually compare each side of my car. Few motorsport joints in Brookvale, I'll head down there.
    • What fuel are you using?
    • I use the flattest and most level piece of concrete I have. And then I shim the tyres on the low side of that with sheets of plywood to level the car. The right amount is easily found with a 2m straight edge and a level or digital angle finder. I use both the spirit level and the same digital angle finder I use to measure the camber. Gives a zero check on the angle finder right at the start.
    • Hi guys,  I'm chasing a recommendation for a turbo charger to suit 600whp.  Engine is a RB25 series 2, with rebuilt forged internals with 8.5 comp ratio. Cams are 262/272. I was considering buying a Garrett G30 770 with 0.83 AR, would it be best to get a V band inlet and outlet to suit as I need to buy a 6 boost manifold as well? Thank you.
