To R34 GTT owners;
How well does the R34 GTT smic handle on 200kw atw tunes?
Any problems with heatsoak on track days and/or long periods of spirited driving?
I currently have a r34 gtt smic on my stock r32 with plans of 200kw~ and was wondering if it will be reliable enough for the above.
People have rated the r34 smic to a maximum of 230kw~ atw but not many have mentioned about heatsoaking issues.
Hopefully there are a couple of r34 members on here with stock smic's pushing out 200kw with no probs?
Trying to decide wether i should install a intercooler waterspray ;)
cheers
https://www.sau.com.au/forums/topic/201406-r34-smic-heatsoak-is-it-an-issue/
Think you should install a intercooler waterspray or go FMIC cuz i reckon even at 180kwrw the SMIC isn't doing such a great job for my GTT R34 especially in summer hot days...
thanks for the info ;)
any other r34 owners with similar experiences?
My car currently has 160kw and havent encountered any heatsoak yet, although not sure how long that will last once i go past 180kw :D
What about improving ventilation around the smic? Like creating more airflow through bumper and undertray mods. I think cutting some small holes in the cover behind the smic will help with heatsoak.
What about insulation (i.e. heat tape/wrap) to keep heat away from the smic?
I reckon these will, at the LEAST, slow heatsoak down. The water spray is good, but i reckon is more finicky.
Not an R34 experience, but may be helpful...
I have an R34 SMIC in my R33, I have full 3" Turbo back exhaust, split dump pipe and Apexi Intake, high boost mod..
Not sure on the power, but at a guess the same as everyone else with these basic mods.
After a "spirited" drive, iv gotten home and thrown a hand on the back of the SMIC (i am missing the inner guard due to R34 SMIC girth and failed clips) just to see, and it is hot.. i mean HOT.
Normal driving on the open road with plenty of boost its similar. Its only cool when i dont give it stink.
One problem i can think of is that the Apexi intake is also very hot, IE sucking in hot air, as i dont have an airbox around it yet.
I dont feel any heatsoak issues or anything like that. It never hesitates or anything.
i got a 34smic on a rb20det 165rwkw and after 'you know' i've stopped,got out and touched both end tanks of the cooler and the hot side was warm to hot and the cool side is suprisingly cool. my experience.
I Ran into heat soak issues on the Dyno at 185rwkw on my R34 with the SMIC on a cooler day it might have been alright. Tuner had to leave it at that since it wasn't doing its job past 185kw went back with a FMIC and he tuned it to 210rwkw straight away.
In summer side mount is crap kills car power heaps.. Had one ditched it in winter, heading into summer because I couldnt handle it any more.. Fmic IMHO is alot better ..
If not use a alcohol or water spray over the cooler however it wont do much because it evaporates quite fast on a hot day. but will help!
Pat, just bite the bullet and install an FMIC with a return pipe that uses the stock hole, don't run a pod and you'll be street legal. and rig it up so you don't have to cut into the bumper support.
failing that, how about two SMIC's :) it'll drop your pressure a bit, but its still legal :)
if anyone is looking at getting rid of there 34 SMIC, please PM me as im keen to purchase one
PM AlexCim
i find my 34 SMIC made a difference when it comes too heat soak compared to the standard(r33 size) cooler. Also feels more responsive.
-Ryan
heat soak on a dyno is due to the fan not directed to give it enough airflow, this doesn't happen on the road.
In short it's not a problem you should be fussed about. Getting traction and brakes are worth more stress and effort than this one on a stock turbo.
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
