After Market Fuel Rail?
From the research i did when i out bigger injectors in I found that the only way i get a new fuel rail is buy using a aftermarket one. whick allows top fed injectors. other than that recomend a fpr
If its only for looks just take the stock one off and have it powder coated or spray paint it yourself.
I'm personally not into bling so I did mine with high temp & oil resistant wrinkle coat and baked it in my G/F's oven (hahaha) for an hour:
Installed (pic taken around 4 weeks ago)
what size injectors you looking at? im sure you can go upto 740's in standard fuel rail anyway... or do you want the -an dual entry type setup, and from the amount of times ive looked for similar thing in standard rail format there has never been a standard aftermarket rail for the rb25 etc side feed style, only many modification standard ones to suport similar -an threads dual entry etc.
 Share
