Hey guys
Woke up this morning(Sunday) and went to go to work at about 630am and both the driver and passenger door of my Silvia, which is parked on the street outside my house, are open. Some low life scum broke in and took some gear.
- RB25 series 1 loom
- RB25 series 1 ecu
- RB25 exhaust manifold
- KKR/JJR430 turbo
If any one has any info on this, sees this stuff for sale cheap, or has a mate that suddenly has this stuff please let me know on 0438187369. This happened on southside brisbane.
Alternatively if the f**kheads who stole this shit return it to me asap I wont ask any questions. If I find out who you are and you dont return it, I wont hestitate to break bones. ;)
Thanks guys
Bren
https://www.sau.com.au/forums/topic/201413-stolen-parts/
not good brendo was the mani/turbo on the motor or inside the car?
I have a Rb25det ecu you could borrow if needed
also will have a R32 rb25De loom when my new motor arives if that can be used
where are you living these days?
Edited by dano4127
https://www.sau.com.au/forums/topic/201413-stolen-parts/#findComment-3580188
I'm thinking that is some serious knowledge of your car prior to the theft. I'd be looking nearby actually. Was the car out in the open or did these guys have some quiet time to get what they needed??
i'm with dave, looks like they knew what they were after.
the problem with the car scene is that alot of people freely share knowledge about what they have/next mods/what's in the build/etc with complete strangers they just met. a little discreetion doesn't go astray.
https://www.sau.com.au/forums/topic/201413-stolen-parts/#findComment-3580213
Thanks guys. Yeh Im thinking it is either someone I know, or someone who knows someone I know, something like that. My house is in a dead end street so its not like they were passing by and decided to break in.
Dano: Thanks for that man, will let you know if I need to use the stuff. Im livin near Sunnybank now, where are you at?
https://www.sau.com.au/forums/topic/201413-stolen-parts/#findComment-3580942
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
