i was ringing around on the weekend to try find some new water hoses, mainly my top and bottom radiator hoses, turns out that the silicon hoses are about 10-15 dollars more then the normal hoses! im just wondering if its worth it? id have to wait longer foe them as well because no shop ever has any "spare" skyrine stuff laying around ;)
i also called lakeside nissan and asked if they had water hose kits, neg. they can import the hoses from japan and im looking at about 300-400 bucks for the lot! wtf hey.
https://www.sau.com.au/forums/topic/201432-silicon-water-hoses/
I am picking up a top and bottom hose from Simon (ministry of bass) today. I asked if he had some available on Saturday, so stock seems to be available.
Any contact details for him not through ebay? I dont have an account.
Thanks
lol wtf?
i ordered a top radiator hose from Nissan, $70 and delivered same day...
keep looking at the top sponsor icons...
or search www.ministryofbass.com
http://www.ministryofbass.com.au
Simon and Joy
Mobile: 0422 894006
email: [email protected]
That should solve the problem LOL
Thanks guys, didn't know he was a sponsor ;)
Edited by JiN_MaN
killa! i just called em up and the bird said i can come past on saturday and pick some up (even tho the shop doenst open officially until the 26th)
::P: thx for the help guys.
Edited by joeleo87
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
