  • Replies 55
It's not new. Back in the 60s, NSW police used Mini Cooper Ss, and they also used XY GTs dressed as Futura 500s.
A few years ago, I spied a WRX sitting up in a cutting waiting to pounce on unsuspecting speedsters near Lake Nilacootie (near Benalia).
In the 60s? How old are you???
Either way, they got in trouble for the P plates a little while ago... Word gets around about what car is a D as well these days... pretty much anything can be, hell, a cop can pull you over in his daughters car off duty if he borrowed it that day...
It blows :D
lulz
Its not the car that gives you away john law
It’s the the combination of a multitude of screamingly obvious car ariels and two, noticeably out of place, grown men sitting behind the wheel or an 06 WRX... wake up, your not going to catch hoons with these n00b tactics
what you need is undercover cop bikes... ffs do WE have to do all the thinking for you?
Already happeing in vic.
Anyone remember the unmarked WRX's years ago? Or the HSV GTO coupe with HSVGTO plates?
I have also been seeing plenty or Ford Territory's and Mitsi 380's getting about with UC's in them.
Yep...Vic TMU had a fleet of WRX's they used back in the early 2000's. Rumour has it that they stopped using WRX's because they kept stacking them :D
Anyway I wonder what the legality is in regard to them displaying P plates when they are on a full licence?
Best way to geta round it is to put up a homemade p-plate that does not comply to the regulations, then it is officially not considered a proper p-plate.
EG - in Vic P plate must be 150mm X 150mm white 'P' on a red background, so just make the thing 145mm X 145mm (Thats also why NSW p-plates are not valid in Vic or those ghey plate people make up by cutting them into patterns or whatever.)
Rumour has it that they stopped using WRX's because they kept stacking them ;)
LOL there may or may not be a shop in Oakliegh that was putting aftermarket ECU's into marked and unmarked WRX's who had multiple pics up on their shop wall of all the stacked and broken rex's they'd seen... Boys obviously cant handle the wrx POWAH!!1!
Edited by ctjet
I spotted a white XR6 turbo undercover pulling peeps over in Werribee last week.
Whilst cruising with Brisbane SAU late last year, a cop in a black 380 UC was having a field day up Mt Coot-tha as there were a number of seperate import cruises up there. The prick was like a fox in a hen house!
Isnt it an offence to have a p plate on if you're a full licenced driver?
nope. just an offence to not have p plates on if you are a p plater
Yep...Vic TMU had a fleet of WRX's they used back in the early 2000's. Rumour has it that they stopped using WRX's because they kept stacking them ;)
im pretty sure the cops stopped using the WRXs coz the speedos werent calibrated right...
Pretty sure that's wrong... Someone was saying that having plates on when he isn't a P plater is an offence... though they rarely enforce it...
Edit: In NSW
I know in Queensland displaying “L” plates and a “P” plate when you’re not on them is a finable offence, which they do enforce here.
I showed my father the story on the link, an he said one of his mates was issued a fine in St Kilda for driving his daughters car with P plates still on
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
