i've got a main key and a valet key. they actually look kinda like factory R32 keys, with the CC logo on em. Old man's got both keys in Syd atm, so can't really take a pic.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3580637
bahaha funny how the most of us dont hav the orgi key,1st time i saw one was on jap yahoo auctions :P
but comparing it to the r32 one, it seem too be an actual circle not an oval type thing like the r32 item.
Edited by Dan_J
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3581505
Yeah, I always wonder that. Everytime I go down the goldy I expect to see my car driven off by some tourist.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3581605
best key I ever used in a car was a customer car that arrived from japan, they had jammed the key blade into a screwdriver handle, so the key looked like a flat head screwdriver to the untrained eye.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3588546
[steal idea]screwdriver handle[/steal idea]
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3590604
i was thinkin of bidding on the 10th anniversary ceffy key, grinding the surface back and engraving "RB20 powah" or some shit on it. cbf with the effort tho.
asked my old man if he wanted it for his ceffy and he had a whinge about how the handle would get hot in the sun and he'd want a plastic cover over the metal... :P
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3592610
  • 3 weeks later...
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
