i've got a main key and a valet key. they actually look kinda like factory R32 keys, with the CC logo on em. Old man's got both keys in Syd atm, so can't really take a pic.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3580637
bahaha funny how the most of us dont hav the orgi key,1st time i saw one was on jap yahoo auctions :P
but comparing it to the r32 one, it seem too be an actual circle not an oval type thing like the r32 item.
Edited by Dan_J
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3581505
Yeah, I always wonder that. Everytime I go down the goldy I expect to see my car driven off by some tourist.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3581605
best key I ever used in a car was a customer car that arrived from japan, they had jammed the key blade into a screwdriver handle, so the key looked like a flat head screwdriver to the untrained eye.
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3588546
[steal idea]screwdriver handle[/steal idea]
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3590604
i was thinkin of bidding on the 10th anniversary ceffy key, grinding the surface back and engraving "RB20 powah" or some shit on it. cbf with the effort tho.
asked my old man if he wanted it for his ceffy and he had a whinge about how the handle would get hot in the sun and he'd want a plastic cover over the metal... :P
https://www.sau.com.au/forums/topic/201472-cefiro-keys/#findComment-3592610
  • 3 weeks later...
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
