Hey guys, my head is off on my rb26, and i would like to know what the block should look like if the oil restrictor is blocked off(as one should be blocked std on the 26's right?), i fear mine has been removed, is it easy to block off if it has?, ive got a tomei gasket kit coming with the oil restrictor included, where do i place this restrictor, and again is it easy to fit?
Pictures would really help me, i dont want to have to pull open the head cause i didnt do these small few things in the 1st place:)
thanks in reply!
Edited by r33turb
Hey guys, another update with a picture off someone elses head(rb26).....could someone please edit the pic and highlight:
1) where the oil restrictors are (and state if one has already been blocked off)
2) where the 2 dowels get placed on the block,because when they done my headwork, they removed the dowels...
Edited by r33turb
yeh from my time talking to ppl there should b already an 2.0mm oil restrictor in the block betwen cylinder 4 and 5 the 1.5mm restrictor just slip straight in on top so ive been told but yeh keep doing ur research i need to aswell lol
Hey guys, just an update, ive now attached the pic(which i didnt do before - DOH!) Please if someone can point out where the tomei restrictor goes, and whether or not i have the 1 restrictor blocked off...that would be great.
Still trying to figure out where these dowels go, im quite certain 1 goes on the corner of the exhaust side cly1, and the other exhaust side, between cyl 5 and 6?(as these holes are slightly more bored than the rest)
Ive been reading the whole oil control article, and think i understand now.....can someone confirm this though...ive attached a new picture. The red area is one of the stock restrictors????, and the tomei restrictor goes over the top of this stock one....is this correct?
the yellow area is the other stock restrictor (which is blocked off because its an rb26dett engine)...is this also correct in saying?
the green area circled is where one of the dowels go for the block?and the other is on the same side but cannot be seen in the pics
Edited by r33turb
R33's are not as prone to this issue as R32's.... I think, unless thats something else to do with oil flow.
Heres the Nengun link to buy buy buy - http://www.nengun.com/tomei/oil-gallery-orifice. Strangely enough it says For RB25&20 but you can only purchase for RB26 :P
Edited by Topaz
I just got a tomei gasket kit today, it has instructions on how to install the oil gallery restrictor, looks pretty easy, batter down the existing one, and put new one in its place (over the top)....couple of quick questions regarding this
1) what tool do you use to hammer the existing 2mm one down
2) is it possible to push the existing 2mm gallery restrictor down too much?, i mean how do you know you've hit it down enough, or too much)???....im just scared of the existing restrictor going down too much when i hit it.....
i assume you hit the existing one down, and then it doesnt go down anymore, then when you put the new tomei one in its place, itll just sit flush with the block?
help please, id like to do this asap!
thanks
r33 turb, correct, red is the standard restrictor and where you would put a tomei one, yellow is the blocked off return. not 100% sure about the dowel location but if you look 2 of the head bolt holes are larger they are where the dowels go.
also, while you are working the oil drain is the rear most holes at the back of the block, strange shaped holes just open them up to the size of the holes in the gasket. (motor out only don't do it to that pic!)
nsta...when you have a hammer every job looks like it needs a hammer. just tap it carefully and straight. once it is flush with the surface of the block you are done
Thanks duncan - that helps a great deal, and clarifies alot aswell. So when fitting the new restrictor over the old one, you place the new restrictor over the top of the exisiting one thats there and tap it down slowly until the new restrictor sits flush?......or would it be better to tap the existing one first ever so slightly, then place the new one over the top (now you have it centered and slightly in the bore hole now) then tap it down.
I just dont want to screw it up as the block is not coming off.
Cheers
no its the first.....just put the new one on top and tap them both down together they will go OK. just be gentle make sure it doesnt go in crooked, if you manage to put it in crooked and score the restrictor you could end up with a metal shaving floating around the bottom end. I've never had a problem though.
so line em up and tap away??? I thought id do this mod while the head is off, i cant do any of the other ones as the block wont be out...hope this helps somewhat with oil blowby....
What kind of tool did you use to tap it with if you dont mind me asking,ill also be doing this mod.
thanks
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
